Is there any such thing as a '09 "Towing Package"? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-02-2011, 03:44 PM
rick980's Avatar
rick980 rick980 is offline
Vehicle: 2015 RAM Quad Cab Sport
rick980 is on a distinguished road
Mine list in the base stuff, on exterior is says Trailer Tow and also 4 and 7 pin connectors, and optional is the classIV hitch but the Trailer Tow was in the Base part, I have a Sport crew cab and I am in Canada if it makes a difference.
Old 03-02-2011, 04:41 PM
Rep:2954
the BUILD SHEET is about 3 pages of everything your vehicle came with
i have found mine to be quite handy on several occasions
i even caught a service writer in a bit of a mistruth, he had not done his proper research & was trying to tell me that i couldn't do something because i needed a certain part, that my Ram didn't have, I showed him the build sheet & he changed his story
a BUILD SHEET will be 3 pages that look like this & goes into detail even right down to the coil spring codes for each of the 4 corners suspension
Old 03-02-2011, 10:56 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
According to this towing guide all Rams with a V-8 (4.7 or 5.7) come with heavy duty cooling. Standard cooling is the only option on the 3.7.
the "tow package" isn't listed b/c everything except for a hitch is standard (hd cooling and 4&7 pin wiring harness).
Hope this helps. If I'm reading the guide incorrectly someone please correct me.
Old 04-02-2011, 02:34 AM
jc4041's Avatar
jc4041 jc4041 is offline
Vehicle: 2009 QC 4wd
Rep:146
jc4041 will become famous soon enoughjc4041 will become famous soon enough
man you guys got ripped off....lol...my ST came with it from the factory
*V9 Cloth 40/20/40 Bench Seat -V3 Dark Slate/Medium Graystone
AJY Popular Equipment Group APAS Monotone Paint
BABS 160 Amp Alternator BC6S 625 Amp Maintenance Free Battery
BNBS Electronic Stability Control BRTS Anti-Lock 4-Wheel Disc Brakes
CBEP 40/20/40 Split Bench Seat CFMP Rear Folding Seat
CGDS Front Height Adjust Shoulder Belts CGSS Supplemental Side Air Bags
CG3S Advanced Multistage Front Air Bags** CJ2P Supp. Side Curtain Frt/Rr Air Bags
CKEP Front Seat Area Carpet CLEP Front & Rear Floor Mats
CSPS Passenger Assist Handle CTLS Base Door Trim Panel
CUES Rear Underseat Compartment Storage DGQ 5-Spd Automatic 545RFE Transmission
DH5S Elec Shift-on-the-Fly P/Time T/Case DJMS 205MM HD Front Axle
DMDS 3.55 Rear Axle Ratio DRBS Corporate 9.25 LD Rear Axle
DS7S Conventional Differential Frt Axle DS8S Conventional Differential Rear Axle
EZH 5.7L V8 HEMI MDS VVT Engine GACS Tinted Glass Windows
GJDS Rear Fixed Window GNAS Rear View Day/Night Mirror
GT6S Power Heated Mirrors, Fold-Away GVBC All Vehicles W/Power Mirrors
GXXS Sentry Key Theft Deterrent System HAAS Air Conditioning
HGBS Dash Liner Insulation HGFS Floor Tunnel Insulation
JAYS Instrument Cluster w/Tach JBFS Instrument Panel Black Bezel
JCBS 120 MPH Primary Speedometer JHAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns JJJS 12V Auxiliary Power Outlet
JKYS Power Accessory Delay JPBS Power Locks
JP3S Pwr Front Windows, 1-Touch,Up & Down JP8P Manual Adjust Seats
LABS Tire Pressure Monitoring Warning LP LCHS Rear Dome Lamp
LE4P Black Exterior Mirrors LMAS Halogen Headlamps
LMGS Automatic Headlamps LPES Cargo Lamp
MBZS Dark Gray Rear Bumper w/Step Pads MCCS Dark Gray Front Fascia
MCLS Gray Upper Fascia MDAS Front License Plate Bracket
MENS Front Wheel Spats MFDS Bright Grille
MGAS Ram's Head Badge MHLS MOPAR Rear Wheel Well Liners
MNAS Black Door Handles MPPP Rear Wheel Spats
MS2S Ram 1500 Badge MUSS 4X4 Badge
MWDS Removable Tailgate w/Caliper Latches MW5P Hemi Badge
MXCS Front Bumper Sight Shields NAA Federal Emissions
NFWS 26 Gallon Fuel Tank NHDP Heavy Duty Transmission Oil Cooler
NHJP Exterior Mirrors w/Heating Element NHMP Speed Control
NHNP Electronically Controlled Throttle NMCP Heavy Duty Engine Cooling
NZDP Next Generation Engine Controller PXR Brilliant Black Crystal Pearl Coat
QXRS Brilliant Black Crystal Pearl Coat RAAC All Radio Equipped Vehicles
RCGS 6 Speakers RDDP Fixed Long Mast Antenna
RESS Media Center 130 CD/MP3 RSCP SIRIUS Satellite Radio
SBAS Power Rack and Pinion Steering SCFS 4-Spoke Steering Wheel
SFBS Front Heavy Duty Shock Absorbers SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar SHFS Rear Stabilizer Bar
SUAS Tilt Steering Column TBBS Full Size Spare Tire
TBMS Tire Carrier Winch TTMS P265/70R17 BSW All Season Tires
TZAP Goodyear Brand Tires WEAS 17X7.0 Steel Wheels
WF1S 17" Steel Spare Wheel WLYC All Steel Wheels
WMJP Center Hub XA8S Non Adjustable Pedals
XBNP Tip Start XBSS Pickup Box
XFH Class IV Receiver Hitch XFKS 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring XJJS Locking Tailgate
X81S Instrument Panel Parts Module X82S Door Parts Module
X83S Front End Parts Module X88S Tire & Wheel Parts Module
Ram DSP, CAI, Cherry Bomb Extreme, AirLift 1000
'07 Dodge Charger SRT8 SuperBee #579-CAI, DSP, dual Cherry Bomb Extremes
'07 GCSRT CAI, custom tune, custom exhaust
Old 04-03-2011, 09:20 PM
Warlord's Avatar
Warlord Warlord is offline
Vehicle: 09 Ram 1500 SLT Quad 4X4
Color: Sunburst Orange Pearl
Rep:13
Warlord is on a distinguished road
I'll have to look at my window sticker again. I swear it mentioned something about the front axle being 2?? mm or something. 214? 244? Might not mean anything.
"09" Ram 1500 Quad-Cab, 4X4. 14" Magnaflo. WeatherTech digital fit floor mats. Need more MODS!
Old 04-03-2011, 11:25 PM
jc4041's Avatar
Rep:146
fronts should be close to the same DJMS 205MM HD Front Axle...who know's though lol
Old 04-04-2011, 06:16 PM
RamJamz's Avatar
RamJamz RamJamz is offline
Color: Austin Tan
Rep:23
RamJamz is on a distinguished road
Looking at my sticker it says under standard equipment, Auxiliary Transmission Oil Cooler. Under options it says 4.7-Liter V8 Engine, just under that, Heavy Duty Transmission Oil Cooler, Folding Trailer Tow Mirriors, Class IV Reciever Hitch.
I was wondering what is the difference between the Auxiliary Transmission Cooler and the Heavy Duty Cooler.
I guess that's pretty much a towing package on the new Rams.
Lonnie
Flowmaster 40, Mopar Polished SS Exhaust Tip, K&N Drop/In.
Old 04-15-2011, 08:57 PM
turk1270 turk1270 is offline
Vehicle: 2009 dodge ram
turk1270 is on a distinguished road
there is no tow pkg per say for the ram the only difference is the hitch is the so called tow package
E Cutout, a Beautiful Thing ScatPak07 Exhaust 26 03-14-2012 12:01 PM
One thing better about a Ford than a Ram Mick Martin Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 12 03-15-2011 05:01 AM
Boredom is a bad thing...well kinda khuman LD RAM - General Discussion 43 06-04-2010 09:00 PM
WTF is this thing?! RamDrvr1500 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 13 06-12-2009 09:49 AM
overhead temp thing? nlh8584 Electrical 2 04-27-2009 10:29 AM
