Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Place your Ad Here!
Old 03-02-2011, 02:28 AM
Hellspawn1 Hellspawn1 is offline
Vehicle: 2011 Ram Sport Crew 4 X 4
Trim Level: Ram Sport 1500 Crew
Hellspawn1 is on a distinguished road
Question Suspension Lift/Rim and Tire Question
I have a new 2011 Ram 1500 Sport Crew 4 X 4.
I wanted to run Toyo M/T's, 37 x 13.5 x 20 tires on 12 inch rims.
Can I get away with a 6 inch Pro Comp suspension lift with this rim and tire combo?
Old 03-02-2011, 11:46 AM
bamasport's Avatar
bamasport bamasport is offline
Vehicle: 2010 Dodge Ram 1500 Crew 4X4
Color: deep water blue pearl
Rep:186
bamasport has a spectacular aura aboutbamasport has a spectacular aura about
the 37's will fit on a 6"lift but im not really sure about going with that wide of a rim. I guess it would depend on backspacing and offset of the tires. You may want to take a look into a BDS lift also, much better system in my opinion, due to the rear springs.
3.92 rear axle, OEM 20" rims, 20% tint, Mopar wheel-to-wheel side steps, K&N drop-in air filter, LineX bedliner, OEM Tow hooks, Rampage Tailgate Light Bar, Borla Cat Back, 6" BDS lift, 35x12.50x20 Nitto trail grapplers, Custom painted interior, dodge slush mats
JON
Old 03-02-2011, 12:07 PM
Rep:3337
The backspacing will be the real issue here. You'll probably need spacers unless you have something like -12mm or more on your rims.
Suspension, Tire, and Wheel Guide 57Hemi08 Dodge Ram Wheels And Tires 168 01-27-2017 06:08 PM
VERY technical question about wheel and tire sizes.. curt4816 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 13 05-03-2011 01:50 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
2004 Ram 4X4 Tire Fit Question???????? 04ram4X4 Dodge Ram Wheels And Tires 4 06-29-2010 10:32 AM
Question about my spare tire YoMoma Dodge Ram Wheels And Tires 7 04-07-2010 01:43 PM
