Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Suspension
Suspension 1st Gen Dodge Ram Suspension Problems and Questions
Old 03-02-2011, 11:52 AM
08ramKING's Avatar
08ramKING 08ramKING is offline
Vehicle: 2008 dodge ram 1500
Trim Level: leather
08ramKING is on a distinguished road
Question Can you use 35" tires with a 2.5"leveling kit??? HELP
Okay so I have an 08 ram 1500, currently has a 2.5" leveling kit and still have the stock 20x10 rims and tires on. I heard some people on here saying you can use a 35" tire with just a level kit and others saying that the max tire size you can use is a 33.and can I still use my stock 20x10 rims??? I'm also thinking of going with a mudd grappler or toyo mt's for tires. Any suggestions?????
Old 03-02-2011, 04:52 PM
I push the skinny pedal
Rep:3225
You sure can. 35s will fit with a leveling kit. You may rub a bit on the upper control arm, and if you do, normally a 1/4" spacer will solve that.
Kurtis
Old 03-02-2011, 05:41 PM
08ramKING's Avatar
Trim Level: leather
Will they fit even if the tire with is 12.5?? I've heard that's too big and a spacer won't make up the difference.
Old 03-02-2011, 05:49 PM
Rep:3225
A 295 series tire will fit with no rubbing, getitng into the 305-325 range then you rub. I'm not at home so I don't have access to my tire size calculator, but a lot of the tires people fit out my way are 35s in the 315 range on a 20" rim and a 1/4 spacer is all they need.
Kurtis
Old 03-02-2011, 05:54 PM
08ramKING's Avatar
Trim Level: leather
Awesome!!! thanks for the help
Old 03-02-2011, 10:19 PM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
^^^CD's gotcha covered!
DODGE the father RAM the daughter!
Official Off-Road tire thread!!!! RamCountry Dodge Ram Wheels And Tires 85 05-07-2014 08:51 AM
35" Tires w/2.5" leveling kit.... curt5878 2011 Dodge Ram Forum 2 03-06-2011 09:50 PM
22" wheels and 35" tires Chops Dodge Ram Wheels And Tires 13 12-08-2010 11:03 AM
No ECO/MDS with 35" tires or greater??? alberta1 2010 Dodge Ram Forum 4 08-29-2010 09:21 PM
Cant find 35" tires to fit my new rims sniperstud1721 Dodge Ram General Discussion 2 08-23-2009 06:08 PM
