Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 03-02-2011, 12:03 PM
iceman5679's Avatar
iceman5679 iceman5679 is offline
Vehicle: 2001
iceman5679 is on a distinguished road
Default Radiator Leak
Hi everyone, My problem started with a gurgling sound coming from the passenger side dash so I checked the coolant level and there was not any in the overflow. I have never seen a leak on this truck in the year I have had it so I'm not sure how it was low on coolant. I added about a gallon of 50/50 mix to the radiator and drove it a couple more days and started noticing a leak coming from the driver side front engine compartment. I could not trace where the leak was coming from due to the blow back but determined it was only leaking while hot and not sitting overnight. It finally overheated and was blowing steam out of the transmission cooler which I thought was odd but it's located on the same side as the leak. I checked the petcock as well and it was tight. I'm afraid I may have a cracked radiator but not sure due to it only leaking when hot. Any help would be great! Thanks!
Old 03-02-2011, 12:06 PM
Rep:1885
You need to pressure test the system to pinpoint the leak.
Old 03-03-2011, 04:59 AM
iceman5679's Avatar
Vehicle: 2001
Default 2001 V10 Radiator leak
Thanks! That was my next step, it's probably the original radiator and with 125,000 on it I'm sure it's due. Any idea if a novice do-it-yourself hack can handle a radiator replacement like that?
Old 03-03-2011, 08:34 AM
Rep:1885
Radiators aren't typically hard to do if you have a decent assortment of hand tools.
Old 03-05-2011, 03:01 AM
iceman5679's Avatar
Vehicle: 2001
Thanks again RamTech, it's sounds like a nice weekend project. I've heard that as long as you can get the petcock loose to drain the radiator it makes for a less messy job.
Old 03-05-2011, 09:34 AM
Rep:1885
Oh, yeah. It makes a big difference.
Old 03-17-2011, 07:58 PM
iceman5679's Avatar
Vehicle: 2001
The pressure test came back with a seam leak of course so a new radiator is imminent. Anyone know where to get a good inexpensive one?
Old 03-17-2011, 08:08 PM
Rep:1885
I've found that cheap radiators are just that - cheap. The only aftermarket brand I trust is Modine.
Old 03-19-2011, 12:28 PM
iceman5679's Avatar
Vehicle: 2001
Thanks I will check those out!
