Old 03-02-2011, 01:48 PM
megadiesel megadiesel is offline
Vehicle: 2006 Dodge Ram 2500 Mega
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
megadiesel is on a distinguished road
Default MegaCab Audio Question
I am thinking about running this setup in my 06 megacab. Tell me if this would work well or not. I am going to put a JVC head unit in, polk 6x9 in the front, and then here is the questionable part. I was wanting to put polk 6.5 components in the rear doors with the woofers in the rear doors and the tweeters in the dash. Trying to pull the sound stage forward some. I was wanting to know if anyone has tried something like this, and what opinions of this setup would be.
Old 03-03-2011, 11:08 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
You should keep the woofer and tweeter of a passive component set within 12" of each other. If you are wanting rear fill, get some coaxials. If you are wanting to keep the stage toward the front, don't use any rear fill.
Now, if you are wanting to run an active setup, there are options...
Old 03-03-2011, 11:12 AM
I will be a passive setup, and the distance was my biggest concern. I may try and find some 6x9 components for the front instead. I just want good sound, I'm not concerned about rear fill. I just want good staging towards the front and a nice upgrade from factory.
Old 03-03-2011, 11:29 AM
Trim Level: Custom
Rep:1648
Will you be amping them?
Old 03-03-2011, 12:36 PM
i plan on it eventually, but to be honest with current funds i will probably not have them amped initially
Old 03-03-2011, 01:14 PM
Trim Level: Custom
Rep:1648
Gotcha, if funds are limited, focus on the front stage, forget the rear for now. Try to source a small 2ch amp for the comps, that is a better option.
2006 Audio question for all cvitech2 Custom Dodge Ram Interior Modifications - Custom Audio / Video 3 02-06-2011 10:50 AM
Megacab driver's question Fast LT1 Dodge Ram General Discussion 3 01-05-2011 05:35 PM
question on audio upgrade Richie Custom Dodge Ram Interior Modifications - Custom Audio / Video 3 10-21-2010 02:20 AM
Audio question shyza Custom Dodge Ram Interior Modifications - Custom Audio / Video 10 09-01-2010 10:49 AM
Question about audio? Ray 2010 Dodge Ram Forum 5 02-10-2010 03:03 AM
