Old 03-02-2011, 02:08 PM
sixwheeler sixwheeler is offline
sixwheeler is on a distinguished road
Default Lower assembly on bumper.
What do you use to paint the lower bumber assemby bright blue like in this pic?
Old 03-02-2011, 02:25 PM
I push the skinny pedal
Rep:3277
...paint...
If you want to do this yourself, get a local auto shop to mix you up a couple of spray cans of color matched paint (Napa has done this for me in the past). Remove the bumper from the vehicle (or do it in place, but you're more likely to have runs that way); degrease the plastic; tape off all the exposed chrome and stuff you dont want painted; sand down (6-800 grit works) just to rough up the surface; spray a couple of coats of adhesion promoter or primer; spray a few light layers of the paint; a few layers of clear coat. Once cured, wet sand with 1500-2000 grit to smooth it out and you're done.
I would also get some 3M vinyl over it as that area is horrible for paint chips.
Kurtis
09-11 Rear Bumper Removal and Replacement marko7717 Dodge Ram Knowledge Base 16 08-01-2014 06:15 PM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
Bad Front Bumper Fascia Replacement/Repair BigEmpty Body & Interior 21 12-01-2010 06:40 PM
New Guy here. . . .looking for front bumper assembly Buff Guy Newbie Checkin! 11 08-04-2010 04:36 AM
Lower bumper grille insert question Brad123 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 7 07-21-2010 04:14 AM
