Old 03-02-2011, 03:45 PM
wester399's Avatar
wester399 wester399 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:100
wester399 will become famous soon enoughwester399 will become famous soon enough
Default Where to put second battery.
Just got my amps installed 2000 watts later and im runnin into obv power issues...light dimming amp circuits shutting down due to low power. Im not too keen on capacitors and i still want to amp my door speakers. Big 3 and bigger alternator are in the plans. Anyone here run 2 batteries if so where did u put the second one really wish the 1500s had 2 battery trays.
Old 03-02-2011, 04:01 PM
Rep:2755
i saw a person post that they removed the air cleaner & rerouted it to another location, using a CAI
I suggest that you upgrade your batteries, 750 CCA
you likely will have to install a battery isolator
a lot of alternators can be tweaked a bit, for more output, in my town there are 2 shops that rebuild generators, alternators, starters, etc. they also tweak the output when asked
Old 03-02-2011, 04:14 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Xtatic Batcap
This is the route I would go next...
Old 03-02-2011, 04:40 PM
I push the skinny pedal
Rep:3322
You can install a second battery in the bed of the truck, or you can order the battery tray from a diesel and set up the 2nd battery where the stock air box would go, then you'd need to custom route your intake.
Kurtis
Old 03-02-2011, 05:26 PM
wester399's Avatar
Rep:100
Already running a yellowtop. Plan is to toss in a kinetik powercell aswell and do the big 3 which will hopefully solve the problems.
Old 03-02-2011, 06:57 PM
blownengine's Avatar
blownengine blownengine is offline
Vehicle: 2003 Dodge Ram
Trim Level: SLT Sport Package
Rep:35
blownengine is on a distinguished road
Wheres your box going? I like the idea of putting the battery and amps under the seat. The battery can sit in the well with only the top showing. And all the wires can be put underneith that top covering piece.
Old 03-02-2011, 07:57 PM
Rep:3322
Having a battery in the cab isn't the best idea when it comes to safety. If it shorts then you're more likely to have a fire in the passenger space. Also, when charging, you can develop toxic fumes... again, not a good thing in an enclosed space. Powercells are put in passenger cabins all the time, I know this, doesn't mean it's a great practise.
Kurtis
Old 03-03-2011, 05:11 PM
Rep:35
Never thought about that...... I saw it once in a Ram and just thought it looked cool. Good info to know.
Old 03-03-2011, 10:26 PM
viper19JN's Avatar
viper19JN viper19JN is offline
Vehicle: 2009 ram 1500 quad cab
Color: mineral gray
Rep:30
viper19JN is on a distinguished road
I mounted mine under the truck between the frame rails right behind the rear of the cab
I built a bracket for a battery box and bolted it to the frame rail worked great
I do have it on an isolater so it doesn't drain the starting battery
Old 03-03-2011, 10:59 PM
wester399's Avatar
Rep:100
ya ive seen that done thanks for all the ideas guys. Ive deceided after some info from dodgeman to rock a bigger alternator and do the big 3 which should end my issues.
Battery drain jdjackson Electrical 4 04-25-2016 05:05 PM
2008 Dodge Ram 1500 - battery chapala01 Electrical 11 12-10-2015 12:19 AM
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 03:59 PM
Battery Isolator WesGPS Electrical 2 04-02-2011 01:43 PM
Battery Won't Stay Charged! taycom Electrical 8 12-22-2010 10:15 AM
