Old 03-02-2011, 06:03 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
Default Its That Time Of Year For...
State Inspection!
Anyway, I went to check truck over (suspension, lights, etc) and I went to see if the passenger side wheel had any play. Sure and shit it does. Even though there is some play on the ball-joints, my wheel bearing is shot along with it. Searched online and even Advance Auto, they carry some brands I never heard of. I want to do rotors as well but my main concern is the wheel bearing. While i'm at it, i'll be doing the drivers side. I already got Moog ball-joints. Mopar wants $500 for the rotor/wheel bearing, already assembled per side. Maybe ill look for alternatives. What good brands are out there?
Pretty much i'm looking for feedback from the 2nd gen 3/4ton crew.
Thanks
Old 03-02-2011, 06:07 PM
Rep:1845
Look for Timken brand bearings. They make a lot of OEM stuff.
Old 03-02-2011, 06:18 PM
panhead's Avatar
Trim Level: WS
Rep:103
Well I was kinda looking into getting the whole hub assembly. After searching for wheel bearings, I believe there is more than one bearing in the hub, along with some other parts and I don't have a press to do the job.
Old 03-02-2011, 06:32 PM
Rep:2616
look at this site for brake pads & rotors, the GREEN STUFF pads seem to be the best
http://www.ebcbrakes.com/automotive/index.shtml
auto parts stores like Pep Boys, Autozone, Advanced, & O'Riellys sell bearings & u-joints that have a less than optimum tolerances, some bearings are just within tolerance, in otherwords, they are built sloppy, sometimes just within .025.
better bearings are within .010-.015
NAPA auto parts carry TIMKIN bearings, they are some of the very best, most of them have a machine shop on site, or will tell you where a preferred shop is located, by the way, NAPA can order all your parts or may even have them in stock
your closest NAPA store is
Bethlehem Auto Parts NAPA
16 West Goepp Street, Bethlehem, PA 18018-2706
(610) 882-1500
Old 03-02-2011, 06:34 PM
Rep:1845
Timken makes the entire assembly.
Old 03-02-2011, 07:07 PM
panhead's Avatar
Trim Level: WS
Rep:103
When I searched Advance Auto, they only showed the bearing and not the bearing.
@GTYankee, thanks for the info and will call tomorrow to find out more.
Old 03-03-2011, 05:09 PM
panhead's Avatar
Trim Level: WS
Rep:103
Called NAPA and they don't carry TIMKIN bearings. The local National Auto Parts carries them and I am looking at $300 a piece.
I can see myself getting raped!
I have to get it, regardless. I haven't checked the other side but I might just get the other side too. Thanks for the help fellas!
Old 03-03-2011, 05:20 PM
Rep:1845
That price sounds about right. I think the last Timken I priced here was $275. Rock auto carries what you need in the GMB brand for about $78 and they have a 12/12k mile warranty. This if for trucks with an 8800 lb GVW rating. It doesn't appear to come with a wheel speed sensor like the Timkens, but it should have provision for it if needed. http://rockauto.com/
Old 03-03-2011, 05:26 PM
panhead's Avatar
Trim Level: WS
Rep:103
I got the LD, not the HD. The hubs are different (3 vs 4 hole hub). Does TIMKEN bearings come with a warranty? I want to go with the best, cause I run a business and down time is unexceptable for me so I prefer getting good parts for the truck. I'm just hoping that the hubs will last for awhile.
Old 03-03-2011, 05:30 PM
Rep:1845
Timken does carry a warranty but I'm not sure what it is off the top of my head. I've installed the GMB's before in other applications and can't say I recall any failures. As far as your application goes, you may need to get in touch with Rock Auto to ensure you get the right part if you choose to go this route.
Drag Racing Tips dodgeman70592 Drag Racing Discussion 32 04-26-2014 10:33 PM
Long time member, long time Vacation. bigthignies Newbie Checkin! 17 01-29-2011 06:54 PM
1st time long time BigT Newbie Checkin! 14 10-07-2010 02:02 AM
Happy New Year everyone!! DaveDees Off Topic Discussion 24 01-02-2009 05:27 PM
It's that time of year!!! MeanGirl Off Topic Discussion 55 11-08-2008 01:03 PM
