Old 03-02-2011, 06:41 PM
green machine green machine is offline
Vehicle: 1994 Dodge Ram
Trim Level: XLT
Color: Emerald Green
green machine is on a distinguished road
Default t.b. spacers
I am thinkingabout putting a throttle body spacer on my 94 with the 5.2. But i am also thinking of shaving the air sleaves down, does n-e 1 know if doing the t.b. spacer will defeate the shaving of the air sleaves?
Old 03-02-2011, 07:01 PM
I push the skinny pedal
Rep:3277
Since you have a fuel injected engine, a TBS won't do anything for the airflow. Milling down the throttlebody will get you plenty of noise from the intake, so adding the TBS will be a waste of your money.
Kurtis
Old 03-02-2011, 07:30 PM
Rep:2657
personally, i think a throttle body spacer makes a good paper weight in a windy auto shop office & not good for much else
Old 03-02-2011, 07:33 PM
Brutus's Avatar
Brutus Brutus is offline
Vehicle: 2006 Dodge Ram
Trim Level: 4x4 Quad Cab Sport
Color: Mineral Gray
Rep:86
Brutus will become famous soon enough
those things are a joke. nothin but a gimmick.
2006 Hemi Ram QC 4x4
2000 AF RC Dak R/T
2000 BW CC Dak R/T
Old 03-02-2011, 07:42 PM
Rep:3277
Not quite. They do have a use (besides paper weights) in carbeurated engines or if you are running a wet nitrous system. The purpose of a TBS is to swirl the air, which increases travel length and increases the turbulence of the airflow. This allows for the vaporized fuel (carbeurator and wet nitrous) to diffuse into the airstream better prior to entering the combustion chamber which gives you a much more efficient and cleaner burn.
Kurtis
Old 03-02-2011, 08:51 PM
Trim Level: XLT
Default t.b.s
Ok thanks guys i think ill b skipping the tbs. I do have to replace the coil was also wondering if n-e 1 had some advice on what to go with cuz eventualy im going to also do the wires cap n all
Old 03-10-2011, 10:09 PM
toddrod's Avatar
toddrod toddrod is offline
Vehicle: 2001 Dodge Ram
Color: Yellow
Rep:55
toddrod will become famous soon enough
8mm MSD wires are good, I'm running a set of them.
Anyone using 5/16" wheel spacers? xopt1js Dodge Ram Wheels And Tires 4 03-02-2011 03:32 PM
wheel spacers tinniste 079 Dodge Ram Wheels And Tires 9 11-22-2010 04:17 PM
Lifting via spacers vs via new struts Tommy Behind The Deuce Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 11-14-2010 10:14 PM
Spacers and leveling kits Bigman 2010 Dodge Ram Forum 1 10-20-2010 08:31 PM
Wheel Spacers causing severe Wheel Wobble nantuzzi Dodge Ram Wheels And Tires 3 06-10-2010 10:17 PM
