Old 03-02-2011, 10:34 PM
wester399's Avatar
wester399 wester399 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:100
wester399 will become famous soon enoughwester399 will become famous soon enough
Default Second battery ...or Bigger Alternator?
So the big 3 is going in regardless. Just wondering what would be better ...a second battery ...or a higher output alternator.
Old 03-03-2011, 10:08 AM
CdnoilRAM CdnoilRAM is online now
I push the skinny pedal
Rep:3277
A higher output alternator would give you more amps available when driving, and up the idle current, a battery will give you longer pull time if you do a lot of idling listening to your tune; but if you can't keep up to the current draw when driving, you'll run into trouble as you can't charge the batteries AND listen to your music.
I'd look into your local shops, some may be able to respool your stock alternator to a higher amperage.
Kurtis
Old 03-03-2011, 10:31 AM
Rep:2657
my '09 alternator puts out 160
i run headlights 24/7
when i am on a job, i run 2 orange rotating lights, they are old school lights, no LED or Strobe, some days i run them for 13 hours straight
i also have a CB radio that is cranked up to 25 or more watts & i am on it constantly while on a job
my alternator handles it quite well & my stock battery seems to be doing quite well
most alternators can be boosted from 140 up to 160, when they come in a stock vehicle, they are set at what is considered a SAFE output, to give it a longer life
Old 03-03-2011, 10:39 AM
Rep:1909
How much wattage/amperage are you going to be pulling? Unless it's an outrageous number, the stock system can handle it.
Old 03-03-2011, 10:43 AM
Rep:3277
He's running a 2,000W stereo Randy, he has dimming and obvious power supply issues.
Kurtis
Old 03-03-2011, 10:45 AM
Rep:1909
Ah, ok. Then I would go with bumping up tha alternator output and using a Bat Cap like the ones Jared recommends. http://batcap.net/
Old 03-03-2011, 10:53 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Adding a second battery, what you need to understand
Old 03-03-2011, 12:44 PM
Rep:3277
That's some great info Jared. And I'm with you on this one Randy, beef up the alternator. His Optima has a good reserve and cranking power, but still has the same lag when it comes to sudden current demands.
Kurtis
Old 03-03-2011, 01:44 PM
wester399's Avatar
Rep:100
Jared your a hero when it comes to audio thanks man
Old 03-03-2011, 01:52 PM
Rep:3277
I know Jared wants to flame me for this... but you can add a 1 farad capacitor and you'll be good, he's not a fan of caps, and neither am I, but to round out all the possibilities, I put it out there.
Kurtis
Alternator won't charge battery? 2011Ram 2011 Dodge Ram Forum 22 11-04-2014 12:45 PM
How To: "Big 5" Basic Engine Re-Wiring Upgrade - Tutorial Valldar Dodge Ram Knowledge Base 24 05-24-2014 04:39 PM
Ram won't start after sitting a few days... Airdog 5.7L (345 cu in) HEMI V8 Specific Topics 67 04-22-2014 10:30 PM
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 03:59 PM
Battery and Alternator upgrade??? wester399 Custom Dodge Ram Interior Modifications - Custom Audio / Video 3 03-21-2010 09:44 PM
