Old 03-03-2011, 03:09 PM
Rep:1877
I know Jared wants to flame me for this... but you can add a 1 farad capacitor and you'll be good, he's not a fan of caps, and neither am I, but to round out all the possibilities, I put it out there.
I thought about mentioning them but held back for the same reason...
Old 03-03-2011, 06:34 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
I'm not that bad.......am I?
WHAT IS A CAPACITOR?
Basically, capacitors are an energy storage device. Large, 1 Farad or more
capacitors store energy (electrons) between their plates. Capacitors differ
from batteries because batteries store energy in the form of chemical
energy--and rely on acid and lead plates, as the place of storage. For a more detailed
description of a capacitor, go here:
http://www.eatel.net/~amptech/elecdisc/caraudio.htm
Then on the right hand side, scroll down to CAPACITOR. Keep in mind the use
of capacitors in an audio system.
WHY DO PEOPLE BUY CAPACITORS?
The number 1 reason would have to be because their lights dim when their
system is playing HARD. In car audio, we are told that a capacitor is
designed to prevent the voltage drop associated with your lights dimming.
The number2 reason is that it is rumored to 'improve' sound quality or
'stiffen' the power supply/source.
WHY DO MY LIGHTS DIM?
Headlights brightness is in direct proportion to the source voltage. For
instance, if your car is running, system voltage is ~12.5 -14.4 VOLTS. Your
lights will be much brighter than when your car is turned off--where battery
voltage is ~12V. Most car alternators put out between 75 to 120 amps of
current. When this current draw threshold of the charging system is
exceeded, system voltage will drop as power demands are now shared by the
alternator and the storage devices (battery & cap). We are using battery
reserves beyond this point until the demand lessens
When playing your system really hard. Your lights dim because your
alternator can't keep up it's charging voltage (around 13.5V) and therefore,
demand exceeds output. When this happens, your electronic devices are
dipping into the power storage of the battery. Since the battery stores
power at ~ 12-12.5V, there is a 1.3 to 1.8V drop in voltage available. This
in turn is why your lights dim down.
HOW MUCH POWER DOES A CAPACITOR STORE?
1 Farad = 100 joules or 100W/second
850cca battery = ~2,200,000 farads
For storage purposes, you'd need ~2,200 1 Farad capacitors to equal the energy of your battery.
Due to its impedence (ESR & ESL), a cap's energy is only 50% available. What's worse, is that in order for a 1 Farad cap to discharge, first the alternator output must have maxed out, and the voltage must have dropped around 1.5 volts. But I thought a cap was supposed to prevent that (voltage drop)!!!!!????? Yep, you got the point.
IF A BATTERY = 2,200 CAPS, THEN WHY BUY A (PUNY) CAP?
My question exactly. Marketing is the reason why people buy caps. In many cases, upgrading wiring will help your system get the maximum transfer of current. Once that has been reached, adding a capacitor may have a minor effect on your system. 50W over the course of a second is not a lot of power considering an amplifier may draw 2000W to put out 1400 watts. Let's look at the situation from a resources standpoint.
Alternator 80 amps
Car accessories (minus stereo) 40 amps
A large Car Audio system (DRAWS ) ~200 amps AT FULL OUTPUT
In this case, you have 240 amps of draw, but only 80 amps of current from the alternator. In your case, you need 160 amps x 12 volts or or let's say 1920 watts of energy. Since a cap stores 50W, how much of a difference do you think it's going to make? A cap is basically a peashooter. We need a Howitzer cannon here, to do the job well.
Also, Once a cap is discharged, where does it get it's power from? The alternator, which is already overloaded. Once a cap is discharged, it's worthless.
SO, WHAT IS A CAPACITOR GOOD FOR?
1. Audio Jewelry- impress chicks with large cylindrical shiny thingy
2. Extra weight in winter time
3. A very POOR... BUT expensive distribution block
4. A projectile in the event of a crash
5. Rolling pin--for cooking purposes
6. A neat thing to tell your friend, "..Hey man, lick the top of this..
Please do not try # 6. New hairstyles are always refreshing, but if you are wearing railroad tracks across your teeth, you might have one big filling after it's over.
HOW CAN CAPACITORS IMPROVE SOUND QUALITY?
They can't. Sound quality is not dependant upon the presence of large bulky 1 Farad capacitors. How many 1 Farad Capacitors do you think the Jay Z, Aerosmith, or Snoop dog use in the recording studio?
IN A NUTSHELL.......
When Richard Clark, our fearless inventor of the car audio capacitor, became World renown for winning every competition under the sun, people began copying what he did. Soon, every 'serious' competitor had a 'stiffening' capacitor--not to be confused with the 'loosening' capacitor.
WHY?
In the late 80s, people began sticking out their tongue when dunking the basketball because Michael Jordan did. Did sticking out your tongue improve your dunking ability? Same here with adding a capacitor to your electrical system.
Old 03-03-2011, 07:05 PM
I push the skinny pedal
Rep:3277
One benefit of a capacitor, is it's very low internal resistance, so when you have maxed out your alternator and your voltage has dropped that 1.5V, the capacitor will discharge the required power, allowing your system to hit the deep draws without affecting the rest of the system. I think it's important to note that a cap is always wired into the system inline and doesn't affect the rest of the vehicle's electrical systems, so when the draw from the battery drops, the capacitor will fill in the rest.
A battery has a much higher internal resistance because it must change from chemical energy to electrical energy, where as a capacitor stores electrical potential. This means it will fire faster than a battery would, and also why Jared recommends the batcaps instead of a capacitor since it's a battery with extremely low internal resistance.
All future new guys reading this and thinking about buying a cap. to fix your bad voltage drops (Below 12v while car is running) or dimming headlights (common sign of non-adequate electrical system), keep in mind this will not help, and if it even seems to help (fixing your dimming headlights) it is not fixing the problem, but merely masking the problem. Your alternator is still being run full-bore at all times when the amp is drawing more current than the alternator can produce. Think of your car battery as a buffer and the alternator as the actual power source.
Yes, caps can help with small voltage fluctuations. No, a cap should not be used instead of buying a high output alternator and deep cycle battery(ies).
I think you actually just made our point
Time a cap is a good thing:
You run a high demand competition audio system WITH THE IGNITION OFF, and your batteries can not maintain their voltage demand fast enough for deep bass hits. A cap will make up for this. This is about the only time I thing Jared would agree that a cap has it's place in the car audio world.
Kurtis
Old 03-03-2011, 11:10 PM
wester399's Avatar
wester399 wester399 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:100
wester399 will become famous soon enoughwester399 will become famous soon enough
Game ...set and match to Jared haha ...i have never been a fan of caps anyways. lol at the 6 reasons tho. I think i have deceided an alternator upgrade and the big 3 ..hopefully with the yellowtop that should iron it out and if necessary a batcap. O btw rep points for all the info man
Old 03-03-2011, 11:30 PM
blownengine's Avatar
blownengine blownengine is offline
Vehicle: 2003 Dodge Ram
Trim Level: SLT Sport Package
Rep:35
blownengine is on a distinguished road
Dodgeman that was one of the best "anti-cap" explainations I have seen. Rep points
Old 03-04-2011, 02:53 PM
Trim Level: Custom
Rep:1648
The most important part of the post is.....
Thanks for the reps!
Alternator won't charge battery? 2011Ram 2011 Dodge Ram Forum 22 11-04-2014 01:45 PM
How To: "Big 5" Basic Engine Re-Wiring Upgrade - Tutorial Valldar Dodge Ram Knowledge Base 24 05-24-2014 05:39 PM
Ram won't start after sitting a few days... Airdog 5.7L (345 cu in) HEMI V8 Specific Topics 67 04-22-2014 11:30 PM
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 04:59 PM
Battery and Alternator upgrade??? wester399 Custom Dodge Ram Interior Modifications - Custom Audio / Video 3 03-21-2010 10:44 PM
