Old 05-07-2011, 02:58 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Vehicle: 2005 Dodge Ram Daytona
Color: GoMango Orange
Rep:13
tones2SS is on a distinguished road
Thumbs up
Very nice. Gotta love the dropped look.
Old 05-08-2011, 01:48 PM
mc1hd mc1hd is offline
Vehicle: 2011 Dodge Ram R/T
Trim Level: R/T
Rep:27
mc1hd is on a distinguished road
Just had this same kit installed and really like it so far, only problem is I think the rear springs are too soft. With just one full size dirt bike in the back the rear suspension is almost touching the bump stops. Really like the look but I still need to be able to use the truck as well.
Old 05-10-2011, 11:48 AM
Jimbob's Avatar
Jimbob Jimbob is offline
Vehicle: 2011 Ram
Trim Level: R/T
Rep:22
Jimbob is on a distinguished road
Yeah thats definitely the issue i'm worried about, I need to be able to put weight in the back and use it like a truck every once in awhile....
Old 05-10-2011, 01:40 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
All you need is a pair of AirLift 1000 helpers if you need to haul/tow anything. $90 quick fix
Slip the empty/compressed bag inside your spring and inflate.
Simply add as much air as you need to level your load with a pump/air compressor.
http://moesperformance.com/index.php...ducts_id=12528
Old 05-10-2011, 05:34 PM
dustin72's Avatar
dustin72 dustin72 is offline
Vehicle: 2013 Dodge Ram1500 4x4
Rep:48
dustin72 is on a distinguished road
I had the Firestone version of those bags in my truck. They didn't make it through the winter. Both bags cracked on the bottom, only 4 months old. I think there have been a few others with the same problem, but I think it may only be in the colder climates.
Black SRT10 22's with 305/45/22 Nitto NT420S Tires, 6000k Low and Fog HID's, Debadged, Tint, Custom Mopar Badges, S&B Intake, Magnaflow Muffler, Superchips Tuner
Old 05-11-2011, 03:52 PM
stangallmotor stangallmotor is offline
Vehicle: 2011 RAM R/T
Trim Level: R/T
Rep:60
stangallmotor will become famous soon enough
Do the air bags just drop in?
Trim Level: R/T
Rep:60
Truck looks great BTW
Old 05-11-2011, 04:14 PM
Rep:554
Yes, but you can deflate and squeeze them in if you like...
Old 05-12-2011, 08:49 AM
iRESQu iRESQu is offline
Rep:2217
The Firestone air helpers were on recall and that is why we went with the same manufacturer as BlackRamHemi. (We are also on a 2/4 BellTech drop and love it!) With the bags in place, I have towed a car, hauled a bed full of wood for our pergola and just yesterday I hauled a bed full of bricks. I merely added 45 lbs of air to the bags (which was far more than I needed) and the ride home was great. Never knew I had anything in the bed.
As far as the drivability or ride of the lowered Rams, my truck does phenominal. There is no "skating" or loss of control in the rear. It hugs the road and corners better. Now if you go over a pot hole or something that size, yes, the rear does feel stiffer.
End belief: If I had to do it all again, I would do the exact same thing. Thoroughly impressed.
Old 05-12-2011, 11:34 AM
Trim Level: R/T
Rep:27
After being told the air lift 1000 would not work because of the 4" drop I called air lift and got the correct part # for the belltech springs. They asked for the inside diameter and ride height of the spring to determine the right bag dimensions.
The correct part # is 61741 for the belltech rear springs, ordered yesterday will update after install. Do not order the off the shelf kit for the oem springs.
Bell tech shocks?! GregInAtl Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 11 02-22-2011 05:43 PM
lowering 2010 ram plainHEMI2010 2010 Dodge Ram Forum 6 01-25-2011 01:59 PM
anyone know how to get just rear lowering springs for 2010 jasondevore Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 2 09-19-2010 10:59 PM
lowering 2010 q/c 4x4? dj913 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 9 08-18-2010 04:24 AM
Lowering tech question... curt4816 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 6 11-06-2009 10:39 AM
