Old 05-24-2011, 11:36 PM
Jimbob's Avatar
Jimbob Jimbob is offline
Vehicle: 2011 Ram
Trim Level: R/T
Rep:22
Jimbob is on a distinguished road
Originally Posted by mc1hd View Post
After being told the air lift 1000 would not work because of the 4" drop I called air lift and got the correct part # for the belltech springs. They asked for the inside diameter and ride height of the spring to determine the right bag dimensions.
The correct part # is 61741 for the belltech rear springs, ordered yesterday will update after install. Do not order the off the shelf kit for the oem springs.
Sounds good - let us know how it goes, it will be great to have another opinion.
Old 05-31-2011, 11:13 PM
mc1hd mc1hd is offline
Vehicle: 2011 Dodge Ram R/T
Trim Level: R/T
Rep:27
mc1hd is on a distinguished road
Easy install and work as advertised so far. Only downfall I can see is when running their minimum 5psi unloaded pressure, truck sets quite a bit higher in the rear. After installing the drop kit the rear end of truck is out of wack.
Old 06-01-2011, 02:33 AM
2011redrt 2011redrt is offline
Vehicle: 2014 RT
Trim Level: RT
Rep:25
2011redrt is on a distinguished road
Pictures? What does out of wack mean? Does it look more like a 2-3 kit????
Old 06-01-2011, 11:41 AM
Trim Level: R/T
Rep:27
Yea, I guess you could say that (2/3 kit). Was hoping it would be the best of both worlds, support the weight and look right. Have to compromise at this point, pictures soon.
Old 06-01-2011, 02:45 PM
Vehicle: 2014 RT
Trim Level: RT
Rep:25
Does it ride good? That's my big concern and I would think the extra inch in the rear would allow a trailer to be pulled without issues.
Old 06-01-2011, 11:19 PM
Jimbob's Avatar
Vehicle: 2011 Ram
Trim Level: R/T
Rep:22
Id like to know what "The rear is out of wack" means too.
Sounds scary. Lol
Does it ride as well with the helpers installed? It sounds like you're not extremely happy with them. Maybe if you let a bit of air out instead of running the recommended 5 PSI it would sit better....
I think i'm going to order the Bell Tech kit this week, probably go with the Street Performance Shocks.
Old 06-02-2011, 08:57 AM
Vehicle: 2014 RT
Trim Level: RT
Rep:25
Sounds scary. Lol
Sorry about jacking this thread but at least we are still on line with "Bell Tech" specifics.... I am also ready to order my kit but need to know the ride and why is sits like it does. There is another post on here about the back being to high but I thought it looked great. The MG kit from my understanding of posts on here leaves the back sitting a hair low and and I need the travel room but like the feedback on ride quality. I just want a good quality kit that rides as good, or bad depending on what you drove before, as the factory ride.
Old 06-02-2011, 12:05 PM
Trim Level: R/T
Rep:27
Ride quality is very good, all I am trying to say is they raise the rear ride height about an inch at lowest recommended air pressure. Air lift says air bags can be damaged (pinched) if you run less than 5psi so that is what I have been running.
<a href="http://s180.photobucket.com/albums/x305/mc1hd/?action=view&amp;current=003-3.jpg" target="_blank"><img src="http://i180.photobucket.com/albums/x305/mc1hd/003-3.jpg" border="0" alt="Photobucket"></a>
Old 06-02-2011, 05:14 PM
Jimbob's Avatar
Vehicle: 2011 Ram
Trim Level: R/T
Rep:22
Yeah bit of a tread jack but its all Bell Tech relevant.
The correct Part # for the helpers is 61741?? Im putting my order in soon hopefully...
Thanks mc1hd for all the info, and figuring this out for the rest of us scaredy cats.
Old 06-02-2011, 11:02 PM
Vehicle: 2014 RT
Trim Level: RT
Rep:25
LOL.... I am sorry for the mistake. I was to concerned about the Belltech kit to understand you were talking about the helpers. Good to know it rides nice and I hope you end up getting the look you want with the helpers. Thanks for all the information.
Bell tech shocks?! GregInAtl Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 11 02-22-2011 05:43 PM
lowering 2010 ram plainHEMI2010 2010 Dodge Ram Forum 6 01-25-2011 01:59 PM
anyone know how to get just rear lowering springs for 2010 jasondevore Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 2 09-19-2010 10:59 PM
lowering 2010 q/c 4x4? dj913 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 9 08-18-2010 04:24 AM
Lowering tech question... curt4816 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 6 11-06-2009 10:39 AM
