Old 03-03-2011, 03:54 PM
MaRvO75 MaRvO75 is offline
Vehicle: 2004 slt quad cab 1500
Color: Almond
MaRvO75 is on a distinguished road
Default HEMI side bed decals install tips anyone?
I bought a set of hemi decals that go top to bottom of my bed on the side. Was curious if anyone has any tips on the install or video by chance?
Old 03-03-2011, 05:14 PM
I push the skinny pedal
Rep:3308
Install is pretty strightforward. Wash and degrease the area really well, I love dawn dish soap for this, rinse it really well, then dry it down with a nice lint-free cloth. Now, measure from the same point on both sides and use a piece of masking tape (i like the blue stuff since it peels off nicer) to hold your decal in place. Get both sides even and taped in a few spots, make sure the decals are perfectly vertical, don't use bed lines for reference, they aren't parallel to the ground. Once it's aligned nicely, you can start peeling the backing off, sa you do this, have a silicone squeegee to push the decal onto the surface and to pull any air pockets. I like to start from the top and work down, but try to be as smooth about this as you can.
Here's a good video, it's onto glass, but same concept. I don't like windex, I prefer the soap; rubbing alcohol is the best though.
Kurtis
Old 03-03-2011, 05:25 PM
sk8noregon's Avatar
sk8noregon sk8noregon is offline
Vehicle: 2008 Dodge Ram
Rep:637
sk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to all
First off, make sure to clean the paint well with a good Wax/Grease Remover. Temporarily tape the pieces in place, and after you have them situated you can place several small pieces of masking tape around the decals and make some reference lines so that you can line it back up when you are ready to apply them. With most vinyl graphics you can use a mild Soap/Water solution and mist the area lightly before application as it will help with any adjustments and air bubbles. If you don't have a Felt Squeege, you can use a credit card or something like that to spread it on and squeeze out any water and air bubbles.
http://m.youtube.com/watch?gl=US&cli...&v=JKHmyhm7Ubo
This video shouild show how the wet application process works.
"Rocky and Bullwinkle"
Join the "Mineral Gray Metallic Ramz Group" here !
Old 03-03-2011, 05:55 PM
Color: Almond
It looks easy and i've put window decals on but i'm nervous about how big they are.
Old 03-03-2011, 06:27 PM
Rep:3308
Just make sure you lay everything out before even thinking about peeling your decal. It's pretty easy.
Kurtis
Old 03-03-2011, 11:04 PM
Color: Almond
ANOTHER question lol Where do most ppl start the decal on these trucks? Do they lap them over the top of the bed or right where the bed starts to bend on the side?
Old 03-17-2011, 02:15 AM
Color: Almond
Still waiting on an answer lol!
Old 03-17-2011, 08:30 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
If you have enough over-lap at the top for the decal to cover top to bottom it's good to let it run to the inside of the bedrail and trim with a razor after you get it all in place.
Good luck, you'll do a great job!
SuperCharged Hemi RAM thanks to Magna Charger azzo540 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 207 06-07-2013 09:30 AM
new to the hemi world tips needed 05bee729 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 9 09-15-2010 11:55 AM
how to install spark plugs and remove them moparmike07 Dodge Ram Knowledge Base 24 07-06-2010 09:42 AM
2010 Hemi exhaust, side exit H22A1 Exhaust 2 06-10-2010 04:56 PM
