Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram – 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 03-04-2011, 03:24 PM
cornishman cornishman is offline
Vehicle: 2003 Dodge Ram Dually
Trim Level: slt heavy duty
cornishman is on a distinguished road
Default Auto box help
Hi guys im'e a newbie on this site so hope i post this in the right place
Im'e from the UK got a 2003 Ram heavy duty slt dually 5.9 diesel 4 speed auto box and in need of advice,bit of a story so i will cut it short
Had geabox driven to destuction in the States ,had it rebuilt by AMCO.
Shipped truck and 5th wheel to UK after rebuild,after about 400 miles gearbox self destructed in the UK,AMCO warranty no go over here
Rebuild number 2 everything now ok done about 3k miles untill monday
No 4th gear all other gears changing ok switching overdrive on and off no different still no 4th,
Under warranty now so on the back of a tow truck to the transmission shop.
Nothing wrong with the box but they say something to do with the box being told its -40 F and will not shift into 4th.
Its +10 c here today
At the moment they are reseaching into the reason why and how to overcome this
Question is ,is there such a setting on the gearbox to stop it changing into 4th ,have you guys come across this before
Thanks for reading this HELP !!! i want my truck back
Ian
Old 03-05-2011, 11:57 PM
Kruzer Kruzer is offline
Vehicle: 2007 Ram 1500
Color: Inferno Red
Rep:36
Kruzer is on a distinguished road
I've seen a lot of wierd trans shifting problems due to corroded battery terminals or bad ground connections in cummins engines. So you might inspect the battery terminals to insure they are properly cleaned. There is a delay in shifting into overdrive if the trans fluid is too cold to prevent damage. Without being able to scan and diagnose the vehicle this is merely a guess. Good luck with your problem.
Old 03-08-2011, 03:11 PM
Thanks for the reply Kruzer
The transmission shop says that is the problem ,the gearbox is being told its -40 f .im'e going to get it back from the shop and give it a good run its 50 miles from the shop to home so maybe it might cure itself with a good run and get the oil nice and hot.
I might add that its only 2 miles from home to work so maybe not giving the transmission chance to heat up on every trip may not help
Ian
5.7 auto tranny duffman Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 1 02-15-2011 04:03 PM
Stick or Auto Quiet Lunatic Cummins Diesel Specific Topics 7 01-19-2011 01:51 AM
Auto up window feature rolls window down 1/2 chefred112 Body & Interior 3 09-03-2010 11:17 PM
Auto Climate control Question SoDakMac 2009 Dodge Ram Forum 11 10-16-2009 01:46 AM
