Old 03-09-2011, 05:26 PM
BRYFRY BRYFRY is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Sport Crew Cab 4x4
Color: Inferno Red
Rep:32
BRYFRY is on a distinguished road
Default what PSI on aftermarket wheel/tire??
How do I find out what is the best/propper PSI I should air my aftermarket tires to?
They are Nitto Terra Grapplers 305/45/R22, and I have an 09 4x4 crew cab.
Do you just go by the "max load" on the side of the tire or is there a better way to determine the right amount of pressure these things should have?
....Also, does anyone know what the recomended poundage I should be torquing the lugs to on these 22" wheels??
Old 03-09-2011, 06:41 PM
Normally I am right at 10 PSI below max PSI listed on the tire.
Before I answer the question on the wheel torque, what kind of wheels do you have?
Old 03-09-2011, 09:00 PM
RamTech RamTech is online now
Rep:1890
Start with the recommended pressure on the B-pillar of the drivers door. If you have 10 ply tires on a 1500, there's no need to run 80 psi in them. This would adversly effect handling and cause the center of the tire to wear prematurely. The wheels torque to 130 ft lbs.
Old 03-09-2011, 09:18 PM
flip16's Avatar
flip16 flip16 is offline
Vehicle: 2010 dodge ram 1500
Trim Level: big horn
flip16 is on a distinguished road
i run my 305's at 47psi... 65psi is max cold load on mine. when the dealer installed them they went to factory specs but they felt flat, they are LT tires which they sold me, LT's do not come factory on 1500's so the sticker on the door would be off. 75% of max should do you fine unless the truck feels bouncey.
Old 03-09-2011, 09:41 PM
Truckkid42 Truckkid42 is offline
Vehicle: 2005 dodge ram :)
Trim Level: SLT 4x2
Color: Fast Yellow
Rep:31
Truckkid42 is on a distinguished road
run your tires where you feel comfortable at. i would say somewhere around 45 would be good. just remember, the higher the PSI, the better the gas and the faster the wear. the lower the PSI, the better the grip. recrememder torque specs is 135 f/lbs. it doesn't matter when you switch wheels, its all about the studs on the truck.
2003 Black Ram SOLD :(
2005 Yellow Rumble Bee #2283
Old 03-09-2011, 09:44 PM
Color: Inferno Red
Rep:32
Thanks guys! That gives me a good idea of what to try them out at.
....They are Boss 329's, black finish with custom black center caps.
-Pics will be coming soon, but I want to finish blacking out some of the trim on the truck to match the wheels before I take pics!
Thanks guys!
Old 03-10-2011, 07:45 PM
Ramathorne Ramathorne is offline
Color: Deep Water Blue Pearl
Rep:48
Ramathorne is on a distinguished road
I run my 285/65/20 BFG AT TA at 45PSI in Winter, 35PSI in Summer and 40psi in the Spring & Fall....
Only exception is is I have to travel during a bad winter storm with lots of snow/slush/ice I knock them back to 35psi and after the roads clear off back up to 45psi I go....
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Aftermarket Backup Sensors space85 2011 Dodge Ram Forum 2 01-25-2011 12:27 PM
Aftermarket Backup Sensors Help Please space85 Electrical 6 01-24-2011 09:26 PM
mygig vs aftermarket mgwarrior350 Custom Dodge Ram Interior Modifications - Custom Audio / Video 5 11-20-2010 03:07 PM
Aftermarket Alarm System phillymac23 2010 Dodge Ram Forum 7 08-23-2010 09:53 AM
