ZDOG
Old 11-08-2011, 01:45 PM
MrPEZO's Avatar
MrPEZO MrPEZO is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x2
Trim Level: Crew Cab Outdoorsman
Rep:38
MrPEZO is on a distinguished road
I need to try this I have had the truck for a year now and tried two different times and now with the new Durango, I need to get them both programed.
2011 RAM Crew Cab Outdoorsman- Nav, Remote Start, 3.92 Gears, Alpine Stero, Mopar Bed Rug w/RAM Head, Mopar Black Side Steps, Tint, Weather Tech In Channel Vent Visors
2012 Durango RT
2006 Charger RT - Mopar Vent Visors, Daytona Blacked Out Grille, BT Catch Can, Air Hammer CAI-SOLD
Old 11-08-2011, 02:08 PM
hyperlitejacko hyperlitejacko is offline
Vehicle: 2011 Black Sport Crew
Rep:20
hyperlitejacko is on a distinguished road
I had the same problem but I have Overhead Doors garage. I went to their website and it walked me through it. However, my remote was working fine and I was following the directions exactly with no luck. I put a new battery in the remote, followed same steps and it worked. So, if all else fails, try a new battery in the remote and then try the garage door manufacturers website.
Old 11-08-2011, 02:41 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
I never had any problems i let my kid program it lol
Old 05-04-2013, 11:26 PM
Laramie in MN Laramie in MN is offline
Vehicle: 2011 Ram Laramie
Color: Blue
Laramie in MN is on a distinguished road
Default Thank You
Probably would have spent all of Sunday trying to figure this out with the instructions in the manual after failing 5 times on Saturday. Used this once with a 2011 Laramie and a Genie opener and it worked perfectly.
Old 05-18-2013, 08:56 PM
jackofall jackofall is offline
Vehicle: 2012 Dodge Ram 3500
jackofall is on a distinguished road
Thanks for this post!! The wife was not very happy with the language she was hearing me speak to my new truck. It blows my mind these instructions aren't on the Homelink webpage.
Old 08-14-2013, 07:24 PM
bedrock bedrock is offline
Trim Level: sport
Color: red
bedrock is on a distinguished road
Thank guys I will try that. When yours didn't work did the red flashinglight work mine don't seem to workwhen you try to eraseany codes
Old 04-26-2015, 02:05 PM
treypt treypt is offline
Vehicle: 2013 Dodge Ram
Trim Level: Laramie Longhorn
treypt is on a distinguished road
Default Homelink Customer Service Wrong!
Thanks everyone for your help. I could not get our 2013 Rams' Homelink to program to our Genie Intellicode garage door opener even though I followed the You Tube video posted by Dodge three times!! Frustrated, I called Homelink customer service. The representative was quick to recommend that I buy a repeater from them for $27 plus shipping and that would get it to work. I looked up the repeater and it did NOT recommend you use it for Genie products.
I was stumped so looked into this forum. Sure enough, if you:
1. Clear programmed buttons by pressing 1 & 3 simultaneously for about 15 seconds, the cluster diplays 'cleared'.
2. Unplug your garage door opener so its not going up and down while doing the next step.
3. Program your desired Homelink button to your existing garage door remote control by holding the remote up to the Homelink panel; hold down the button on the opener's remote control while holding down the Homelink button you want to program to the garage door until you see 'learning complete' in the display.
4. Plug in your garage door opener and press the learn button on the opener; on mine it was a little red button; the led on the opener begins to blink.
5. Run back to the truck and press the button that you programmed in step 3; hold for 2 seconds; press again for 2 seconds. The second time I pressed it, it operated the garage door and had programmed successfully.
Thanks again to everyone who posted here and I hope my Genie Intellicode specific issue helps others who get the wrong information from Homelink.
Old 04-30-2015, 10:28 AM
thake618 thake618 is offline
Vehicle: 2011 Dodge Ram Laramie
thake618 is on a distinguished road
what do you mean dumped the codes?
Old 04-30-2015, 10:52 AM
Obsessed's Avatar
Obsessed Obsessed is offline
Trim Level: Outdoorsman 4x4
Rep:20
Obsessed is on a distinguished road
I have a Craftsman with rolling codes. I only had to do step 4 and 5 you listed above. Piece of cake. I think you can ignore all that other garbage. I pressed the red button, and the button I wanted to program it to, and voila. Programmed.
Old 04-30-2015, 10:54 AM
Obsessed's Avatar
Rep:20
I think he means clearing out the memory of the Homelink.
My Diablo Won't Reinstall Stock Tune - Problem Solved! Big Daddy Diablo Predator Questions & Info! 11 10-06-2011 09:57 PM
Tranny problem solved? (Warning) dirtsurferus Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 6 08-31-2011 10:56 PM
Door Ajar Light & Power Windows Problem. scottdutton Electrical 1 12-05-2010 05:54 PM
Problem not solved Griebz 2009 Dodge Ram Forum 21 09-16-2010 07:42 PM
Body lift steering extension problem solved JMaxx93 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 0 05-26-2010 12:08 AM
