Old 03-05-2011, 07:19 PM
BCWhite BCWhite is offline
Vehicle: 2003 Dodge Ram ST 4.7L V8
Rep:14
BCWhite is on a distinguished road
Default Proper PSI on Aftermarket wheels
Do you follow what is stamped into the tire or something else? New to this and just bought a truck with aftermarket rims and tires.
Old 03-05-2011, 08:04 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Stock tires are 35 psi, how big are the tires on it now??
Old 03-05-2011, 08:27 PM
mitsocruiser's Avatar
mitsocruiser mitsocruiser is offline
Vehicle: 98 dodge ram
Trim Level: 2500 sport
mitsocruiser is on a distinguished road
You take the max psi labeled on the tire and test when they have been setting for 3 hrs or more .You should then set the psi atleast 8 pnds less than the max to acount for swelling once they warm up. I personally set mine 10 pnds lighter to give a little breathing room.
Old 03-05-2011, 08:28 PM
My current tires max psi is 80 pnds so it verys by brand just be sure to check your tires max
Old 03-05-2011, 08:29 PM
I am usually at least 10 psi below the max psi. But what kind and size of tire is on the truck now?
Old 03-05-2011, 08:34 PM
I believe mine are 265/75/16 I have a 98 2500 so my tires are D class to take care of 6000 pnd stock weight
Old 03-05-2011, 08:36 PM
I also have a mitsubishi eclipse with 225/45/17 that take 55 psi so it all depends on tire the max psi will be on the side of your tire in small writing ussually inside off a little circle
Old 03-05-2011, 10:48 PM
Rep:14
Mine are Mickey Thompson Baja ATZ 325/50R20.
http://www.summitracing.com/parts/MTT-5120/
The writing on them says max psi is 65. I got them to 50psi today as the right rear was low and out of the 4 that one had noticeably more tread wear. Those are what was on it when I bought it.
Old 03-05-2011, 10:55 PM
916Timmy's Avatar
Rep:1443
I would call a local tire shop and ask them! That seems like a lot of pressure!
Old 03-05-2011, 11:00 PM
Rep:14
Mickey Thompson 5120 - Mickey Thompson Baja ATZ Radial Details
20'' Wheel Diameter
Weight: 75 lbs
Load Range: E
Max Load: 3085 lbs
Max PSI: 65 lbs
Approved Rims: 9.0"-12.0"
Measuring Rim: 10.0"
Section Width: 13.2"
Tread Width: 10.8"
Overall Diameter: 33.0"
Tread Depth: 19/32"
This is from another site. Says 65 max.
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
What are the closest aftermarket Ram wheels to the McFly truck? chrismeyers2k1 2011 Dodge Ram Forum 17 03-03-2011 12:14 AM
Which wheels? jcasey10 Dodge Ram Wheels And Tires 9 09-28-2010 09:28 PM
Cold Air Intake F/S....Diablo Predator F/S....Moto Metal 951's F/S Zack Birge Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 12 07-25-2010 12:50 PM
Aftermarket wheels on 09 ram ? boomerboomer 2009 Dodge Ram Forum 8 02-07-2010 09:21 PM
