Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Suspension
Suspension 1st Gen Dodge Ram Suspension Problems and Questions
Old 03-06-2011, 01:13 AM
Tom Tom is offline
Vehicle: 1989 Dodge Ram 250 4X4
Trim Level: base
Color: Grey
Tom is on a distinguished road
Default Steering Box adjustment
I'm looking to adjust the play in my steering box as it is fairly sloppy and I was wondering what is the usual protocol? adjust until screw is tight and tighten lock nut? adjust until tight, back off 1/4 turn or more? any input would be much appreciated.
1989 Dodge PowerRam 250, 4x4, 318 v8, Dana 60 rear, Dana 44 front.
Old 03-06-2011, 01:28 AM
Check and make sure your steering components are good first . I'd adjust the play a 1/4 turn at a time if it's needed .
Old 03-07-2011, 07:49 AM
Tom Tom is offline
Trim Level: base
Color: Grey
Ok, thanks for the input.
Old 11-17-2012, 08:56 AM
ProDodge ProDodge is offline
Vehicle: 84 Dodge W350
Trim Level: Custom
Color: Blue
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
ProDodge is on a distinguished road
Never, ever seen this worlk out as it get loose again..............
Red head steering box out of seattle
84 Dodge W350,08 TBSS,97 GT Mustang, 80 Ford Bronco XLT
Old 11-23-2012, 09:48 PM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
My expirence has been that the loosness is usually out side the box. Have you had someone turn the steering wheel while you look at the steering box and steering shaft? There repair kits for both. Also an examination of your steering componets may be in order.
Old 12-06-2012, 12:08 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Check the bushing in the intermediate link. My Ramcharger had to be rebuilt. (Just above the box...roll pin holds it in/together)
My steering column woes and how I cured them DaSOB Dodge Ram General Discussion 9 01-08-2015 04:29 AM
New Mods and a DIY for steering maintence sullivan Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 02-23-2011 11:10 PM
Body lift steering extension problem solved JMaxx93 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 0 05-26-2010 01:08 AM
Remerson228 last airbag question awful knawful 2009 Dodge Ram Forum 5 05-17-2010 08:42 PM
changing clockspring awful knawful Body & Interior 2 05-08-2010 06:27 PM
