Old 03-08-2011, 01:48 AM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
392 stroker kit i do with a new tranny have setup
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 03-09-2011, 10:45 AM
sawcut64's Avatar
sawcut64 sawcut64 is offline
Vehicle: 2005 Dodge Ram
Color: Grey
Rep:24
sawcut64 is on a distinguished road
Got an Inertia 400CI/6.5L stroker in my truck that Stu and I put together(mostly Stu), and I think the biggest he goes in a 5.7 is 407CI. I work for Inertia and do all their Texas installs, and every time I'm down to his shop it's littered with motors being built and Hemi parts all over the place. Even with a 5.7 bored and stroked to 400, it should still see 80-100K without a need for a rebuild. If you want a MAX life out of a stroker then I'd stick with a 5.7 based 370 or 6.1 based 392....personally I want MAX power and am willing to sacrifice a little life for a little more power. From a 370 to 400 is 30 cubes and probably 30+ HP.
2005 RCSB 2WD Hemi Ram
Inertia 400CI/6.5L Stroker, Inertia Custom Cam
Old 03-09-2011, 12:45 PM
I push the skinny pedal
Rep:3308
Thanks for that info sawcut, it's great to have people who can chime in on this stuff. I think a 392 stroker might be in the works for me anyhow
Kurtis
Old 03-11-2011, 04:08 AM
MOOSEFIRE66's Avatar
MOOSEFIRE66 MOOSEFIRE66 is offline
Vehicle: 2002 Dodge ram 1500 4X4 4.7L
Trim Level: SLT ??
Color: Fire Truck Red Baby!
MOOSEFIRE66 is on a distinguished road
You don't have to take your motor out for any of this do you? I would assume that it could be done underneath the truck..... also does this require a custom tune or similar?
Aftermarket reverse lights, Emergency lights, New tires.......More to come!
Old 03-11-2011, 04:15 AM
srtsir's Avatar
srtsir srtsir is offline
Vehicle: 2004 Dodge Ram
Rep:198
srtsir has a spectacular aura aboutsrtsir has a spectacular aura about
Thats a great title, is that what you call yours HEMI....lol...
5.7 HEMI, DIABLO, K&N INTAKE, MBRP CATBACK, 4.56 MOTIVE, DMH E-CUTOUTS, 22X10 SRT-10 RIMS (BLACK), 315/45/22 COOPER ZEON XST'S, 2/4.5 MCGAUGHYS DROP KIT, 6K HID'S FOGS & HEADS, RECON L.E.D TAILGATE STRIP, EFX ROLLPAN, TRUXEDO LO-PRO, HORNBLASTERS 156DB TRAIN HORN, HONEYCOMB GRILLE....
Old 03-11-2011, 09:30 AM
sawcut64's Avatar
Color: Grey
Rep:24
You mean build a stroker? Hells yeah you have to remove it, dip it, machine it, build it, paint it, install it, and custom tune it.
Old 05-18-2011, 04:28 AM
Badass's Avatar
Badass Badass is offline
Vehicle: 2003 Dodge Ram
Badass is on a distinguished road
If your thinking of stroking your 5.7L you should find your local Callies dealer and by it, rotating assembly, through them cause you will save yourself some money. Depending on the year of your truck you may have some tuning issues. I'm in the middle of sorting mine out right now and could use some opinions myself. This much i know, don't go to crazy with your cam if your a 2003-earlie 2004, because they are harder to tune for idle control.You will also need 6.1L injectors and a CMR Diablo tune. I tried using stock injectors and naturally Im running lean
392 with tuning issues PLEASE HELP!!!!!
Old 04-18-2012, 10:21 PM
RickRoss's Avatar
RickRoss RickRoss is offline
Vehicle: 2004 Dodge Ram 2500
RickRoss is on a distinguished road
Glad I found this thread!!!! I am lookin to stroke my hemi as well!! I have been lookin for all the info I could find. I am lookin to stoke it to a 392 Stroker, but 400 sounds so much more powerful!!! Who do I need to talk to about that and how much is the kit? Can I just buy the kit from them and git the machining done by my machinist?? If you can give me the prices for al of the kits!!!
Old 04-18-2012, 11:22 PM
TheSatinPumpkin's Avatar
Color: Satin Orange
Rep:627
www.shophemi.com
www.inertiamotorsports.com
Folks should assist you with all your questions.
Old 04-19-2012, 02:15 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
I built probably the first Eagle based ram block 400ci Stroker, bought a balanced assembly from Inertia and dropped it in my 09 just make sure you get a huge cam or you will have a very low timing motor like what i have atm. The 400ci is a 6.6l it rounds up just like the 345 5.7l's...
I bought a balanced rotating assembly from stu is around 4k another 500$ for machine work and i would recommend using an ARP bottom end main stud/side stud kit anouther 250$ or you will rip the guts out of the bottom end on the factory bolts... Also if you plan on boost you need to drop the compression ratio to around 9:1... if no boost in the the future run a 11.1 cr.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
SuperCharged Hemi RAM thanks to Magna Charger azzo540 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 240 11-30-2015 01:19 PM
Free Hemi on Base No Options short cab short bed 2010 1500 cyberpine 2010 Dodge Ram Forum 19 07-21-2011 01:54 AM
What makes a Hemi a Hemi? M n M Dodge Ram General Discussion 12 02-08-2011 08:02 PM
