Old 04-19-2012, 04:20 AM
KarateManAZ's Avatar
KarateManAZ KarateManAZ is offline
Vehicle: 2009 Dodge Ram
Trim Level: MagnaHEMI
Color: Deep Water Pearl Blue
Rep:120
KarateManAZ will become famous soon enoughKarateManAZ will become famous soon enough
I am in talks right now with stu to do a 370 stroker for my magnacharger. Once I get it done I will run 18-20 psi..... I'm excited!
2009 Ram 1500 Crew Cab - Deep Water Pearl Blue
2/4 Drop, 0212353 Retro Shop Projector Retrofit w/ custom paint, Jet 180 T-Stat, AR LT Headers, 545rfe w/ deep pan,
Inertia Cam, Edge Triple Disk, Magnaflow 18"
Oh Yeah its a MagnaHEMI 12.2@109
Old 04-19-2012, 11:30 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Originally Posted by MOOSEFIRE66 View Post
You don't have to take your motor out for any of this do you? I would assume that it could be done underneath the truck..... also does this require a custom tune or similar?
Yeh have fun with that lol how can you get the pistons matched to the block if its still in the truck?
The motor has to be pulled and the block must be completly stipped down to bare and off to the machine shop you go. There it will get cleaned, bored, line honed and mostlikely they will replace the cam bearings along with other things and they will clean it again.
Once you get it home you can install the mainbearings and the crank along with the main caps. At this point you go through every cylinder and check for clearance issues with the rod bolts and if there is then you clearance the block with a die grinder. Once every cylinder is clearanced then you clean the hell out of the crank, main bearings, main caps, rod, rod bearings, and the block to remove any metal particles. And reinstall the crank, main caps, main bearings and bolt em down.
Next part is the most time consuming putting the pistons on the rods and making sure you put them on correctly direction wise. Then the fun begins of gapping rings NOT!!! lol !! Mine are gapped for boost. Now you drop the piston/rod in one by one and torque it all down and stretch the bolts.
Time for the cam install, then the timing case, oilpan, and all the sensors you took off can go back on. then just drop the sucker in and bolt it to the trans and the motor mounts.
Then its just a matter of putting the lifters in gaskets on heads/headers attached, rockers, pushrods, spark lugs, valve covers, coil packs, intake mainfold, power steering pump, ac comp, starter, throttle body, hook up the wiring, all the hoses, the belt, intake, and fill it with fluids. I almost forgot about the exhaust...
Put a custom tune on it and your ready drive with smiles per gallon!
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
SuperCharged Hemi RAM thanks to Magna Charger azzo540 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 207 06-07-2013 09:30 AM
Free Hemi on Base No Options short cab short bed 2010 1500 cyberpine 2010 Dodge Ram Forum 19 07-21-2011 12:54 AM
What makes a Hemi a Hemi? M n M Dodge Ram General Discussion 12 02-08-2011 07:02 PM
