Tranny Shifting Problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-06-2011, 04:39 PM
an4rchy's Avatar
an4rchy an4rchy is offline
Vehicle: 2001 Dodge Ram 1500
Color: Dark Blue/Silver 2Tone
an4rchy is on a distinguished road
Default Tranny Shifting Problem
Hi Guys
Wondering if you could help me with the problem I have been having. Hopefully I can explain.
So the main problem is my truck is not holding 2nd gear. when climbing a hill at low speed it will hold till about 2000rpm then want to drop back to 1st.
when back in first it will rev out and not change up until I take my foot off the gas. then it will change down. this keeps happening till I can get it about about 70/80km/h then its will slip into 3rd.
I live in Alberta, Canada in cold temperatures but this happens when the truck is cold and warm. It is a problem when I'm driving lots of steep windy roads.
the truck has done just over 150,000Kms
It is also slow to change gears and one cold morning it took a long time on the highway to change into overdrive but I have not had that problem since. As far as I know it has a new transfer case too. I dont have huge tires or lift kit.
Any help would be awesome. thanks in advance!
AN4RCHY
Old 03-06-2011, 05:06 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
This could be a mis-adjusted throttle valve cable that controls the trans shift pressure. Here is a link to the service manual information on how to adjust the Throttle valve cable on the 2001 Ram.
http://www.ramforumz.com/attachment....2&d=1299359369
brad
Interested in one of my mods?
Old 03-10-2011, 10:20 AM
an4rchy's Avatar
Thanks for your help. I have printed off the instructions and will get a friend to give me a hand with the adjustment soon. Hopefully it sorts out the problem.
I'll post the results when I do.
Cheers for your advice!
AN4RCHY
Old 03-10-2011, 04:04 PM
Resident Technician
Rep:1915
When's the last time it was serviced and had a band adjustment?
Old 03-11-2011, 10:24 AM
an4rchy's Avatar
Not sure. I bought the truck in December and had an oil change last month but thats it. Got new spark plugs and sepentine belt I have to put in.
Why do you ask? Is a band adjustment common when serviced or do you have to ask for it to be done?
AN4RCHY
Old 03-11-2011, 10:47 AM
brad12kx's Avatar
Rep:2581
You'll probably have to request it. Considering it's year, having the trans serviced would be a prudent thing to do, unless it's been serviced recently. I believe it is recommended every 60K miles (100K km). Check with your dealer, and ask for a estimate to have it serviced so you don't get hit with an 'unexpected' bill. Trans service is quite a bit more expensive than a basic oil change, but is generally well worth the investment.
brad
Old 03-15-2011, 12:00 AM
an4rchy's Avatar
Rang around and got a few quotes. anywhere from $200 to $350. $350 gets you a full flush and wash!
I will book it in to get done soon, no idea when it was serviced last so its probably a good idea to have it done.
AN4RCHY
Old 03-15-2011, 12:07 AM
brad12kx's Avatar
Rep:2581
Keep us posted as your experience/results. It can be difficult at time to try to diagnose a problem without actually seeing/touching/smelling.....you know what I mean. So am always very interested in the final results.
brad
'01 Dodge Ram 4wd shifting problem CloneSaw Cummins Diesel Specific Topics 2 02-10-2011 01:25 PM
Tranny problem - uh #3 tranny? Come on! TLars Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 5 02-09-2011 03:35 PM
2002 5.9 v8 tranny problem jeepfreak96 5.9L V8 Specific Topics 5 01-12-2011 05:04 AM
03' Dodge Ram 1500 4.7L Magnum - TRANNY PROBLEM - Did the shop screw my tranny up? emodpro 4.7L PowerTech V8 Specific Topics 3 09-16-2010 02:53 PM
shifting problem jimmy14 5.2L V8 Specific Topics 0 05-16-2010 09:09 PM
