Recommendation needed - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 03-06-2011, 06:46 PM
nancyh1980 nancyh1980 is offline
Vehicle: 2006 Laramie 3500
nancyh1980 is on a distinguished road
Default Recommendation needed
My husband and I purchased 06 laramie 2-wheel drive drive with auto transmission. I am now the sole owner of this 140,000 truck. I don't tow. This is my primary driver (primary highway miles). It has been a most unreliable truck I have ever owned. Aside from the unresolved steering click click, I have rebuilt a tranny due to a bad torque converter(paid dealer $4K). Now I hear a thump noise each time I accelerate or change from reverse to drive. My co-workers drove and got underneath the truck and think it is the rear end.
1) Any idea of how much rear end costs? This is the standard ratio that came with the truck.
2) Can you recommend a trust worthy shop in or nearby Houston that I can have them fix all the issues I have?
Thanks so so much
Old 03-06-2011, 07:23 PM
Rep:2968
before thinking it is the rear end
get the drive shaft Universal joints checked, they could have worn bearings, that could cause noise with a jarring sensation, if it is the problem, it is an easy less costly fix
if it turns out to be the rear differential, do your research, decide whether you want a highway or a pulling truck, highway gears would give you better mileage possibly
check general parts prices here, to give you an idea of what it may cost, so that you won't get sticker shock
http://www.ringpinion.com/
some shops in your area, look for AAA, ASE, BBB accredited shop
BAYTOWN --- http://www.pylebros.com/ many people recommend this shop
Houston------http://www.circledtrans.com/custom_applications_conversions.php
Texas Auto Gear ----this shop doesn't even have a website, but, may be worth checking out
314 West Carby Road, Houston, TX 77037-3723 (281) 448-4371
Good Luck
Old 03-08-2011, 06:47 PM
You were dead on. It was the 2-piece U Joint. $500 later this issue is fixed. Randy's Drive train and Sam were wonderful.
(3) issues left:
1) The front steering popping happened from they one. I guess no one can ever solve this.
The other 2 - easy. New shocks and replace brakes.
Throughout my sponsorship by Bilsteen, they sent me new shocks for the truck.
Approx $ for changing the shocks (using my shocks) and brake jobs on all 4 wheels including turning the rotors.
Gents, thanks so so much
Old 03-08-2011, 07:03 PM
sk8noregon's Avatar
sk8noregon sk8noregon is offline
Vehicle: 2008 Dodge Ram
Rep:637
sk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to all
I would have suggested checking the u-joints first as well just as GT did. Now for the $500 price tag ! That seems a bit steep to me. I haven't had to replace them in my Ram yet but in my Chevy they are $45 a piece and I replaced them myself. Just curious as to th high price tag is all. Glad you got it fixed though. As for the steering knock, do you have excessive play in the steering wheel ? You could check the Drag Links or possibly the Sreering Box itself.
"Rocky and Bullwinkle"
Join the "Mineral Gray Metallic Ramz Group" here !
Old 11-23-2011, 11:01 AM
mkobliska mkobliska is offline
Vehicle: 2006 2500 4x4 Diesel
Trim Level: Big Horn Edition
mkobliska is on a distinguished road
If the steering "popping" you are refering to is a "clunking" feeling in the steering wheel and also in the brake pedal...check your steering shaft. I replaced mine and its better than it ever was. Spend the extra $$ and get the Borgenson instead of stock...far superior ($270 for the shaft, 1/2 hr to install).
Much needed love boosted20v Dodge Ram Pictures - Photos 9 11-24-2010 12:14 PM
Needed a new battery Patriotblue07 5.7L V8 Specific Topics 1 06-11-2010 02:53 AM
Tire recommendation Shug Dodge Ram Wheels And Tires 9 05-19-2010 10:50 PM
Recommendation on LSD brusk Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 04-17-2010 12:31 PM
Cummings lubricant recommendation? wenders LD RAM - General Discussion 4 10-19-2009 09:47 PM
