Old 03-06-2011, 09:39 PM
BCWhite BCWhite is offline
Vehicle: 2003 Dodge Ram ST 4.7L V8
Rep:14
BCWhite is on a distinguished road
Default Limited Slip?
How do you tell if you have a limited slip differential? I am researching synthetics to put in my vehicle and this question came up. Here is my rear diff from the build sheet.
2003 Dodge Ram
Corporate 9.25 LD Rear Axle
Old 03-06-2011, 10:22 PM
Rep:1845
The build sheet should show if you have it. If it's not on the sheet, you don't have it.
Old 03-07-2011, 03:29 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Do you see anywhere the letters LSD or the wording 'Limited Slip' in the same line as the word 'differential' or 'rear axle' ? If not, you likely don't have it.
brad
Interested in one of my mods?
Old 03-07-2011, 03:45 AM
Rep:2616
2 ways to tell either way,
if your rear wheels are off the ground, like on a shop hoist, spin either rear tire, if the turn in the same direction, it likely has LSD
if they spin in opposing directions, then you don't
now if the truck is sitting on the ground, put it in low gear, push hard on the skinny pedal & release the brakes, turn the vehicle around & count the strips of burnt rubber, either 1 strip or 2
Old 03-07-2011, 10:23 AM
I push the skinny pedal
Rep:3277
I like option 2 for checking for LSD... the cops have other opinions though, ones that I don't agree with.
Kurtis
Old 03-08-2011, 12:55 AM
Tommycat Tommycat is offline
Vehicle: 2004 Dodge Ram
Rep:22
Tommycat is on a distinguished road
General rule I go by: If you're asking if you have it, you probably don't.
Old 03-13-2011, 11:57 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Cd.....not all cops are against that method!!!! Just don't do it at the huge intersection during rush hour with Granny sitting behind you in her 1982 Oldsmobile. Atleast move into the parking lot.
My Build Sheet, Do I have Limited Slip Diff al2ride 4.7L PowerTech V8 Specific Topics 7 11-03-2011 11:35 PM
Adding limited slip user zero 5.2L V8 Specific Topics 7 03-29-2010 12:46 PM
Limited slip trluby Newbie Checkin! 9 01-26-2010 10:46 PM
Aftermarket Limited Slip Mike Maples 2009 Dodge Ram Forum 0 07-22-2009 05:44 PM
Limited slip differential buzzdoyle Dodge Ram General Discussion 2 12-19-2008 02:30 PM
