Old 03-06-2011, 11:19 PM
sindelir3020's Avatar
sindelir3020 sindelir3020 is offline
Vehicle: 2010 Dodge Ram 1500 quad cab
Trim Level: sport
Color: silver
Rep:22
sindelir3020 is on a distinguished road
Default Cb Radio/ Antenna Mount
I saw a post awhile back as to where to mount a CB and or Antenna. Hope this helps some of you guys out I made mine so it could be completely disconnected very easily. My Antenna is 4ft Wilson Fiberglass; picture shows it disconnected and can be connected withing minutes. Uniden Radio peaked and tuned to 2 watt dead key, w/4 pin cobra mic. Antenna has been tuned as well. Very Loud Radio!! Made Radio so I could hook it up by cig/plug very easy to do so I can make it very portable.
Old 03-06-2011, 11:32 PM
Nice setup . GT Yankee has a 4th gen Ram and has a CB in his for his business . Hopefully he'll see this thread and post up his pics .
Old 03-07-2011, 12:02 AM
old hot rod's Avatar
old hot rod old hot rod is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Rep:386
old hot rod is just really niceold hot rod is just really niceold hot rod is just really niceold hot rod is just really nice
Send a message via Yahoo to old hot rod
Nice set up, I've got a Ranger 66 cranked up to 15 watts but have not installed it yet.
My truck doesn't have the console, so mine will be done different but thanks for the ideas.
Hell Bent Steel Leveling kit, K & N filter, Tinted Windows,
Mufflex DOD18M, Mopar Intergrated Trailer Brake,
DiabloSport Predator (U7137) 180 Thermostat, WeatherTech Vent Visors
DiabloSport Catch Can (C-1040)
Old 03-07-2011, 03:26 AM
Rep:2616
where you have your radio mounted would wear out my right leg, i keep my leg resting against the center console, having just the mic cable coming out at my right leg, sometimes irritates my leg
most of my runs are 190 miles one way & then i have to drive back home
my radio is a Ranger RCI6300F150; 10M AM/FM only Versions of RCI-6900, Small Fan cooled design on F150, it is TUNED & converted to 11 meter, i am putting out 50 watts & it is not FCC approved
[IMG]
my portable unit, that is an emergency radio that i also rent out to the Highway Patrol on occasion
[IMG] [IMG]
Old 03-07-2011, 08:14 PM
Trim Level: sport
Color: silver
Rep:22
Looking to upgrade my radio, any ideas or where to get a nice loud radio without having to pay a arm and leg??
Old 03-07-2011, 09:28 PM
Rep:2616
if you just want a Cobra or Uniden, they have them at FRY's electronics, ( they are the sons of FRY's grocery stores in Arizona ), just off the 17 Phoenix, AZ
3035 W. Thunderbird Road
Most truck stops have them too, as well as other brands, if you go to one of them, look at the different antenna mounts
Kustom CB & Stereo
6741 West Latham Street, Phoenix, AZ 85043-1401
look at the better known CBs for Truckers
Ranger Communications
Galaxy
Connex
General Lee
online websites
http://www.walcottcb.com/radios-c-340.html
http://www.gijoesradioelectronics.com/default.asp
http://www.claysradioshop.com/
http://www.radioactiveradios.com/articles/
almost any CB can be TUNED or MODified, but, don't look here, FCC doesn't like it
http://www.radiomods.co.nz/framesmodspage.html
Old 03-07-2011, 09:39 PM
Trim Level: sport
Color: silver
Rep:22
Thanks for the info it was very helpyful, but at the same time I am a new radio hobbyist. What do you recommend? I want something that I do not have to worry about getting stepped on.
Old 03-07-2011, 10:35 PM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
There are a lot of good radios out there. Depends on if you want to go "pro" or hobby. GT above left so good info.
The antenna and it's mount is of UTMOST importance. Long & high. When was the last time you saw a semi with a 4' fiberglass antenna mounted with 2' below the cab?
I run a "tuned" Cobra 29 radio mounted like sindelir3020 with a Wilson 1000 antenna in the center of the roof.
You will always get stepped on by the big boys with the BIG radios. I don't have that much money or need.
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 03-08-2011, 02:54 PM
Ramathorne Ramathorne is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Color: Deep Water Blue Pearl
Rep:48
Ramathorne is on a distinguished road
where did you run your coax into the cab at?
Old 03-08-2011, 04:48 PM
Rep:2616
you will always get stepped on & when it happens & you & who you are trying to communicate with just have to decide on a different frequency (channel )
truckers mostly use 19 & 31
Mexicans will be on 5, 6, 7, & 10
all the other frequencies will be hit & miss
most truckers & base stations will have a booster amplifier ( linear ), some of them are real A-holes & spend their money on boosters & noise makers, some will put out 1,000 watts, we can't talk over them
many base stations like to shoot skip, when the Sun Spots are just right, they can talk to God, coast to coast is nothing for them. We on the other hand, according to FCC rules, can only talk about 20 miles, its referred to as line of site, so 2 people sitting on high hills 20 miles apart, can speak to each other legally, using only a standard legal 4 watt radio. IF you want a little booster, get one that is capable of 100 watts, but only use 50 or 75 watts of it. Otherwise you will get a knock on your door, loss
of your equipment & a possible $75,000 fine
Seeing as you are only starting out as a hobbyist, get a reconditioned cb if you can Cobra 25 LTD or 29 LTD
https://www.cobra.com/category/mobile-cb-radios-2-2.cfm
or a UNIDEN 68 or 78
http://www.unidendirect.com/itemlist...pe=prd&catid=5
get a Wilson antenna, not a Firestick, believe me when i say that there is a difference, i don't use a fiberglass antenna, although many people do, the antenna Match or tune is VERY important. the ground is very important too, if you put it on your bed, ground the truck bed to the cab body & even the frame if you want
a VERY GOOD microphone is a Telex Turner Roadking 56, if you need a 4 pin microphone, almost every place that sells CBs will have them, it is what i bought after my original mic went bad, to use one, you almost have to have your mouth touching the mic to use it though, because it is a noise canceling microphone
any other questions that you have, I or someone else will answer or try to answer it
Ipod/Iphone cable rerouting and vehicle specific mount install on RER radio mph300 Custom Dodge Ram Interior Modifications - Custom Audio / Video 13 02-01-2012 12:09 AM
Satelite Radio Antenna MuzzledRooster Body & Interior 7 03-23-2011 10:19 PM
Where did you mount your antenna? Ramathorne 2010 Dodge Ram Forum 10 02-22-2011 02:44 PM
Shaved radio antenna Fast Willy Custom Dodge Ram Interior Modifications - Custom Audio / Video 7 10-14-2009 08:34 PM
Radio antenna sidewound Dodge Ram General Discussion 3 08-16-2009 03:53 PM
