can it be rebuild - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Old 03-07-2011, 09:31 AM
tndodgecwc's Avatar
tndodgecwc tndodgecwc is offline
Vehicle: 2002 dodge ram
Color: silver
tndodgecwc is on a distinguished road
Default can it be rebuild
do yall think that the motor i have can be rebuild
Old 03-07-2011, 02:38 PM
Philctr1982's Avatar
Philctr1982 Philctr1982 is offline
Vehicle: 1999 dodge ram 1500
Philctr1982 is on a distinguished road
Send a message via Yahoo to Philctr1982
That would be dependant on if you ruined the block. If the block is fine then any motor can be rebuilt. although buying a new one is not really as exspensive as one may think. I know for a 4.7 at Napa you can get it with the return of your old motor for core at around 1600.00 dollars, Or if you want to go to a junk yard to pick up one that may have low miles, prob right around 5 to 8 hundred, but be sure to take off all of your sensors from your old motor so you have them incase one is bad on the engine you get. Hard lesson that I have already had the privalge learning. Take it easy
Old 03-07-2011, 02:57 PM
Rep:2929
without knowing a lot more, it is difficult to even make a guess about your engine
first is or was your engine running when you decided it was in bad shape
is there any holes in the block that don't belong there, like a rod knocking a hole in the block
has the engine ever been rebuilt before, a lot of engine blocks can be rebuilt 2 or even 3 times, depending on the thickness of the cylinder walls,
are there any visible or INVISIBLE cracks in the block or heads
there are many other considerations to be taken into account, but, i think that i covered the main ones
Old 03-08-2011, 07:17 PM
tndodgecwc's Avatar
Color: silver
you said that napa has my motor for 1600? is that short or long block?
the was running when i took it out. it has never been rebuild. it was making
a few sounds knocking and squealing.
Old 03-08-2011, 08:13 PM
jerry donihoo's Avatar
jerry donihoo jerry donihoo is offline
Vehicle: 2014 Ram Express reg cab 4x4
jerry donihoo is on a distinguished road
Im just hoping mine last longer than 9 years
Old 03-08-2011, 08:27 PM
tndodgecwc's Avatar
Color: silver
your motor is a new 4.7 it should not have the flaws the the old ones have. i know if you rebuild it the rocker arms are dif and a lot of other stuff has bigger oil ports and junk like that. your 08 should be fine. as long as you dont dog the Hell out of it, like the guy did mine.
Old 03-09-2011, 06:39 PM
RumbleRam's Avatar
RumbleRam RumbleRam is offline
Vehicle: 2002 Dodge Ram QCSB 4.7L
Color: Light Almond Pearl
Rep:30
RumbleRam is on a distinguished road
the 08's are fine, but as far as to say rebuild your motor, i'd have to see some pics of it, i dont know what you need to do it though, is it a rod knock? lifter tick? sometimes a cracked flywheel can sound like a rod knock, pretty much just need details i bored mine over .020'' and put new heads on it and it and i've no problems with it at all, but i did have some problems with it before the bore, the motor sludged up and pop a rocker arm off, got two new heads (well i though i did) and and it fixed that....then
the intake valve seat on the #6 came out and hit the piston, got a free head for that side since it was under warranty....piston was fine no major damage, then i melted Piston #7 because my injector wasn't plugged in completely and the comp didn't detect it, i going to flash my PCM back to a 2002, because ever since the Dealer did it in 2004, i've had nothing but troubles since they flashed it, but as far as it being repaired it can do it, i have plenty of rebuild photos, and i have the ENTIRE 2002 dodge ram book. the one Dodge gives to the dealer that tells them EVERYTHING about the Truck it took up 5 2in ringed binders i can e-mail it to you i'f you like it
My 1998 5.9L Engine rebuild 5point9LARAMIE4X4 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 68 05-20-2016 03:52 PM
47RE transmission rebuild mgarlock00 Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10 6 01-14-2011 10:24 AM
4.7 rebuild = big money!! deerslayer1521 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 1 12-01-2010 01:40 PM
Transmission Rebuild - Common? mgrasber LD RAM - General Discussion 10 02-05-2010 08:45 PM
Is this a good price on tranny rebuild bwoodredkneck LD RAM - General Discussion 2 01-22-2009 02:42 AM
