Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 03-07-2011, 03:25 PM
john garman's Avatar
john garman john garman is offline
Vehicle: 2009 Dodge Ram
john garman is on a distinguished road
Default When do I change Oil
On a 2003 5.9L diesel with 0w40 full synthetic how often would you change the oil.
On my gas engine with full synthetic I change it every ten thousand kms
Old 03-07-2011, 03:30 PM
Rep:1885
Diesels are a lot dirtier inside. I'd recommend 8000 kms.
Old 03-07-2011, 05:35 PM
Mcbride's Avatar
Mcbride Mcbride is offline
Vehicle: 2011 ram 1500 Crewcab 4x4
Trim Level: Sport/SLT
Rep:13
Mcbride is on a distinguished road
+1. I actually do mine every 6,000 to 7,000 kms, but I also prefer dino oil.
Changing it lots is the key in my opinion.
Get the dirt, fuel, etc. drained out.
Its not a mistake that mans best friend cannot talk.
Old 03-07-2011, 08:41 PM
Thanks Guys
thats what the manual says but I thought it was just for regular not synthetic
I don't mind changing it more often but @ 12 liters its going to get expensive
Old 03-08-2011, 06:54 PM
Mcbride's Avatar
Rep:13
Originally Posted by john garman View Post
Thanks Guys
Synthetic gets dirty, and contaminated with acids, fuel etc. just like dino oil does.
I use dino oil in my trucks.
Old 03-15-2011, 03:44 PM
Midnight's Avatar
Midnight Midnight is offline
Vehicle: 2004 Doge Ram 2500 Cummins TD
Trim Level: SLT Laramie
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
Midnight is on a distinguished road
Send a message via MSN to Midnight
The only way you can get more miles out of your Synthetic is to add a ByPass filter system. This adds a second filter to your system that continually filters very small particals out of the oil while the main oil filter removes the standard stuff. There are plenty of sights out there explaining ByPass filter systems...The big rigs use them as changing their oil is more costly than yours since they use twice the amount of oil.
oil change warning revisited.... muskybait 2010 Dodge Ram Forum 11 05-26-2011 10:32 PM
Oil Change and Quick Change Valve wallym777 Oil Change 16 03-06-2011 05:55 PM
Qucik change oil valve-check!.. - messy oil filter change - options ? alecmcmahon 2010 Dodge Ram Forum 14 03-05-2011 06:19 PM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 01:00 AM
Oil Change Message clatla 2010 Dodge Ram Forum 24 08-21-2010 03:20 AM
