Old 03-07-2011, 07:43 PM
NUTSHEMI's Avatar
NUTSHEMI NUTSHEMI is offline
Vehicle: 2011 Dodge Ram
Rep:67
NUTSHEMI will become famous soon enough
Default Oil change question.
I did my first oil change at 3500 miles, the oil change light never came on. I put in penzoil full synthetic with a K&N filter. I figured I would change it at 8500 miles. Well the message just pop up today at 7500 miles. Do you guys think I can hold off till 8500 cause of the synthetic and not pay attention to the message or should I change it out now.
Old 03-07-2011, 07:49 PM
RansRAM's Avatar
RansRAM RansRAM is online now
Addicted to the Z
Color: PX8 Black
Rep:2471
Well I put synthetic in mine at 5000km, the reminder came on at 8000km so I just reset it. I think you'll be fine but it is your choice. Just make sure your change intervals are at least as frequent as the owners manual states.
Old 03-07-2011, 08:30 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Yeah, key to run position without starting the motor and press the gas pedal down three times to reset it!
Old 03-07-2011, 09:14 PM
NUTSHEMI's Avatar
Rep:67
So the message is just a reminder? The truck is basically preset for that? I rember one dealer saying it should go off every 3k and it measures viloscity. I guess they don't calculate for the synthetic which you can run longer.
Old 03-07-2011, 09:22 PM
cudase's Avatar
cudase cudase is offline
Trim Level: Sport Crew Cab
Color: Mineral Gray Metallic
Rep:53
cudase will become famous soon enough
The controls system cannot calculate the viscosity of the oil. It would require a viscometer or spectrometry analysis to do so, and it would be very cost prohibitive. The newer vehicles(our trucks), and some older ones like my ancient 1998 buick, calculate oil life based on duty cycle. Numerous data curves are applied, to determine the rate at which the detergents in a conventional sae approved oil will deteriorate to the point of needing to be replaced, based on how you drive. Drive really aggressively all the time or allow short engine run cycles and you will be changing early.
What to know how your oil is really doing when you change it, send a sample to BlackStone Labs
Old 03-07-2011, 10:13 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Vehicle: 2011 dodge ram Quad Cab 4x4
Trim Level: chrome
Color: red
Rep:60
Freightrain will become famous soon enough
I think the new corvettes actually measure viscosity. My question is if I drive my truck in city conditions for 8 months but only have 2500 miles on it would when would you change it?
"The End is Near, I'm just gonna get there a little faster"
Volant CAI, 4" Nerfs, Tonneau Pro Cover, 18" Magnaflo, more to come
Old 03-07-2011, 10:51 PM
snyds snyds is offline
Trim Level: SLT Outdoorsman
Color: white and pewter
snyds is on a distinguished road
Depends if you want to keep your warranty valid, and like your engine. If your vehicle is out of warranty then I would wait as long as 12 months to change the oil if its has less than 5,000 miles on the oil change interval. Manual says to change it 8k miles or 6 months. It's best to do what the manual says, or change it sooner. I would never let my oil and filter get past 7k miles. I use conventional oil and change it and the filter at 4-5K in summer and 5-6k in winter. That's just me though
Old 03-07-2011, 10:57 PM
cudase's Avatar
Rep:53
I doubt it. Viscosity is temperature dependent and the tools(viscometer) required to accurately measure it would cost more than the corvette itself. GM still uses the same algorithm in the new vette that they use in my old buick, it is slightly modified to take into account extra cylinders, fuel usage, and engine demands.
You should have changed it at 6 months(IIRC from the manual), if the duty cycle calculator did not tell you to change the oil as it is only a duty cycle calculator and will not count time from last oil change and degradation from change.
Old 03-07-2011, 11:04 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
On a brand new vehicle you should follow the owners manual recommendation. That way it can't be used against you in the case of a dispute.
brad
Interested in one of my mods?
Oil change question on 2009/2010 MightyBlueRam Oil Change 40 08-18-2013 05:20 AM
New guy with the $400 4x4 v10... now i gotta question dirty dodge Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10 8 10-08-2012 11:00 PM
Oil Change Question? CityGuy24 2010 Dodge Ram Forum 17 12-10-2010 11:31 PM
Oil Monitor Reset Question Mr. Ed Cummins Diesel Specific Topics 4 10-03-2010 08:20 PM
2/4 lowering question jjhwick119 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 11-13-2009 09:31 PM
