Old 03-07-2011, 07:40 PM
RumbleRam's Avatar
RumbleRam RumbleRam is offline
Vehicle: 2002 Dodge Ram QCSB 4.7L
Color: Light Almond Pearl
Rep:30
RumbleRam is on a distinguished road
Default 2008 Intake
i was wondering if anyone here has put the 2008 intake on a 2002-2007 4.7L, im think about doing that mod with the adapter plate and AIT power wire re-locator from airram, and was wondering about if vacuum line placement would change and also if it needed to be tuned once i install it
Old 03-07-2011, 08:04 PM
THasse THasse is offline
Vehicle: 2012 Ram 1500
Color: Dark Red
Rep:44
THasse is on a distinguished road
I was on here a couple days ago and somebody posted a do it yourself CAI. If I were you, I'd look into that personally. And it was for the 4.7.
Mods: Deleted Resonator, painted talgate logo, DiabloSport tune, K&N drop in. Plenty more on the way, finances permitting...
Old 03-07-2011, 08:25 PM
RumbleRam's Avatar
Rep:30
I know about the C.A.I, and i plan on putting one on, but im talking about the Intake Manifold itself, the 2008 has 350mm intake runners compared to my 415mm intake runners, the 2008 manifold which makes stronger top end HP and low end TQ, i just think the install would be pretty tricky, because i dont think the AIT is on the manifold anymore, but im not for sure
Old 03-07-2011, 08:28 PM
sk8noregon's Avatar
sk8noregon sk8noregon is offline
Vehicle: 2008 Dodge Ram
Rep:637
sk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to all
What exactly are you refering to when you say AIT ?
"Rocky and Bullwinkle"
Join the "Mineral Gray Metallic Ramz Group" here !
Old 03-07-2011, 08:43 PM
RumbleRam's Avatar
Rep:30
Air Intake Temperature Sensor, on the 2002 on the 4.7L it's on driver side body on the intake manifold, right behind the Idle Air Control (IAC) and Throttle Position Sensor (TPS)
Old 03-07-2011, 08:46 PM
sk8noregon's Avatar
Rep:637
I just installed a K&N a few weeks ago on my 08 and the sensor is on the intake tube. However, the tube wasn't drilled out because of that reason, not sure if the one your looking at is drilled out though. I can post some pics if you'd like ?
Old 03-07-2011, 08:51 PM
RumbleRam's Avatar
Rep:30
yes please, but your saying it's not on the Intake manifold anymore, so i'll have to relocate it, which if fine, but yes please post some pics, because also i would like too see how i may have to re-route some vacuum lines and other things, and your pics would be a HUGE help
Old 03-07-2011, 08:58 PM
sk8noregon's Avatar
Rep:637
Here are some pics of the K&N installed, if you have any questions you can post them here or PM me.
Old 03-07-2011, 09:04 PM
sk8noregon's Avatar
Rep:637
I had sort the same issue when I was looking to buy an intake, but reverse from yours. LOL. I wanted a Volant but they only had them up to 07, skipped 08, then from 09-up. I couldn't get any good info on where the 07 stuff was located as to the 08 so I ended up buying the K&N kit.
Old 03-07-2011, 09:05 PM
RumbleRam's Avatar
Rep:30
thanks that help kinda wrap my mind around the install now, but when and if you get the time i'd like to see a picture of the back driver side of the intake, kinda were the brake booster line is going to, just a close up of that would be nice too if you have on that is. thanks
3.9/5.2/5.9 Intake Removal & Installation RamTech Dodge Ram Knowledge Base 6 08-28-2013 05:03 PM
4.7L build up begins! .40 over 10:1 + 10PSI + 100SHOT = OMG! AIR RAM Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 29 12-06-2010 12:21 AM
