Transmission Fluid Change - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Diesel Forums!
Dodge Caliber
Old 03-07-2011, 09:45 PM
Jack772 Jack772 is offline
Jack772 is on a distinguished road
Default Transmission Fluid Change
I read, in one of the truck forum, somebody changing their transmission fluid at 30k miles. I didn't see in my '09 owners manual anything about changing at 30k.
Whats the lowdown on this?
Old 03-07-2011, 10:19 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
From what I have read Dodge trannys have been very delicate for many years. I have learned it is best to change the fluids every 30K miles and that's what I follow. Hasn't caused any problems so I guess it works. I had neighbors with a Ram that lost their tranny at 40K (probably no maintenance & hard driving). I don't know about the newer Dodge trannys, but I have followed the same schedule with my wife's 08 Rav. Only costs a few bucks and can cave you a bundle in money and headaches. If your tranny has a dipstick then go for it, it's easy to do. If no dipstick, then it's a little more complicated, but do-able. Ramtech will probably chime in with his opinion soon enough.
www.beatcraigslist.com - for posting dangers & secrets
Old 03-07-2011, 10:30 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1230
With Dodge's and their "Dodgy" trannies, I go ahead and do a drain and refill/filters every 30k. (or 6th oil change, whichever comes first), at around $100 to DIY (including fluid) its cheap insurance for me.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 03-07-2011, 10:34 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
Jack, 60,000 miles is the first place I can find it in the owners manual's recommended maintenance. Doing it earlier won't hurt anything especially if you are towing or off roading.
Old 03-08-2011, 11:29 AM
Bozo's Avatar
Bozo Bozo is offline
Vehicle: 2013 Ram
Trim Level: Laramie Crew Cab 4X4
Color: Copperhead Pearl
Rep:327
Bozo is a jewel in the roughBozo is a jewel in the roughBozo is a jewel in the roughBozo is a jewel in the rough
I don't mean to highjack your thread, but I am curious about this too.
How difficult is it to change the tranny fluid? I change the oil in my Mistress every 5,000 and the worst part about it is the location of the filter and the hassle of keeping oil drain off the R & P. I would have no problems tackling this as long the process and tools are similar to the oil change. Currently, she's at 26,xxx so this will be needed before summer.
Cheap, Fast, Reliable; you can choose only two.....
Old 03-08-2011, 11:58 AM
Rep:55
Tranny drain & fill are easy but can be messy. 1-Look for the tranny pan under the truck, does it have a drain hole? If so open & drain. If not, drop pan, make mess, clean up mess. 2- Drop pan, clean off all gasket material. 3- Replace filter. 4- Put new gasket back on and close up pan. 5- Use dipstick no refill tranny fluid to proper level. 5a- If no dipstick then use whatever special tool is needed to refill. 6- Drive around a bit then go back and recheck fluid level. Simple! Anyone with a few tools can do it.
Old 03-08-2011, 12:46 PM
Resident Technician
Rep:1915
http://www.ramforumz.com/showthread....t=maintainence
Old 03-08-2011, 03:32 PM
ArmyofOne's Avatar
US Army Retired
Rep:1230
Its not difficult, but there is no gasket made for our trucks transmissions. It is an RTV Silicone sealed pan. It is EXTREMELY messy if you dont have a plug. Next time I do mine, I am going to Drill/Tap and install one.
Worst part about changing the tranny fluid is working around the stupid exhaust pipe. Service manual says take off the Y-pipe. I never do, saves an hr, but causes some cussin'.
Old 03-08-2011, 04:03 PM
Rep:55
Wow, that's a PITA for you guys! I have plenty of clearance to do mine. Y pipe is in front of tranny, and tranny support is behind the pan. I have heard that Dakotas have to remove the tranny cross member, but don't know for certain. My only problem has been the lack of drain plug. I intend to remedy that next time I do a drain. It does get way too messy otherwise.
Old 03-08-2011, 05:08 PM
Rep:2929
i just turned 40,000 miles
waiting on shipment of Royal Purple for both the tranny & differential
filter(s) will be MOPAR
new differential cover delivery will set the change date, this is the cover
http://www.mag-hytec.com/store/index...31efbaf03241bd
i will also have a DYNO run done that day, just for the hell of it
Transmission fluid change mikeraz1 5.7L V8 Specific Topics 9 04-22-2015 10:03 PM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 01:00 AM
Transmission Fluid Change Help! DavidV951 5.2L V8 Specific Topics 3 09-16-2010 07:16 PM
change the transmission fluid moparmike07 5.7L V8 Specific Topics 32 08-02-2010 11:40 PM
Very Odd Transmission Fluid Issue mck89 4.7L PowerTech V8 Specific Topics 4 06-08-2010 11:36 PM
