Old 03-08-2011, 09:24 AM
Bruce E's Avatar
Bruce E Bruce E is offline
Vehicle: 2013 Ram Longhorn Crew Cab
Trim Level: Longhorn
Rep:55
Bruce E will become famous soon enough
Default Trailer towing
So here's the deal. I have towed trailers all my life but always with a manual transmition. My current truck is an automatic. Next month I will be travelling from Ontario to Alberta and back again (7000km). I'll be towing an 18' enclosed trailer empty going out and loaded coming back. Do I need to leave the truck in tow/haul mode all the way when on the highway?
Vararam Cai, ARE Cap, 35" Dick Cepek Mud Country, DC-2 Wheels, Diablo Trinity.
Old 03-08-2011, 09:55 AM
HawkFan1's Avatar
HawkFan1 HawkFan1 is offline
Vehicle: 2005 Dodge Ram 2500
HawkFan1 is on a distinguished road
I tow a 29.5 foot travel trailer and I leave mine in tow/haul the entire time.
Old 03-08-2011, 09:56 AM
Rep:1877
If you're on flat land at highway speed, you're ok to take it out of tow/haul mode unless you find it's frequently shifting or unlocking the converter.
Old 03-08-2011, 01:43 PM
BigThirsty's Avatar
BigThirsty BigThirsty is offline
Vehicle: 2004 Dodge Ram 2500 4X4
BigThirsty is on a distinguished road
With an enclosed trailer, yes, keep it in T/H. You are going to have a s**t ton of drag. You can try towing normal but I'm willing to bet it will hunt for gears and you will still kill your mileage. My truck does not like to tow under about 2k rpm's.
I hope the newer tranny's are better than the 2004. My T/H still allows it to go to OD (4th) which causes some hunting of gears on hills and also causes the TC to lock and unlock constantly. Drives me nuts but there is nothing I can do about it unless I want to back down to 50-55 and use 2nd all the time. My Duramax/Allison had me spoiled I guess.
2004 Dodge Ram 2500 4X4 5.7
Old 03-08-2011, 03:08 PM
Bruce E's Avatar
Rep:55
Thanks for the info guys. Other than northern Ontario the rest of the trip should be fairly flat I believe. Going to be spending a bundle on fuel I know.
Old 03-08-2011, 08:20 PM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
Tow/Haul will lock out double overdrive and put you in standard OD 4th / ERS "5" as well as chose more aggressive shift points. Dont be afraid to use ERS to lock out higher gears in the hills to allow you to use a lower gear and still roll out of it to less than full throttle when climbing. Also if you press and hold the "-" button when descending it will downshift to the correct gear for optimal compression braking.
Gene
Old 03-08-2011, 08:57 PM
dafoot dafoot is offline
Vehicle: 2011 Dodge Ram, 1500, Hemi
Rep:16
dafoot is on a distinguished road
I would suggest, using the joy stick, and stay in 4th.
DAFOOT
Old 03-08-2011, 09:59 PM
pjs1660's Avatar
pjs1660 pjs1660 is offline
Vehicle: 2011 ram 1500 outdoorsman
Trim Level: slt outdoorsman
Color: green
Rep:137
pjs1660 will become famous soon enoughpjs1660 will become famous soon enough
i tow a 25' camper and base it on the road conditions i usally use tow/haul when it's hilly and shut it off when it's flat
What do I need to know about towing a travel trailer car421 Towing 17 08-10-2011 07:34 PM
No power to trailer brakes, the blue brake wire has no current rraypo Electrical 1 01-09-2011 10:55 PM
Towing two trailers (triple towing) rking300 Towing 6 12-02-2010 08:07 AM
Your opinion on towing... Tootall Dodge Ram General Discussion 7 09-04-2010 07:27 PM
Tekonsha P3 Trailer Brake Controller Doesn't Recognize Trailer GTRDude Towing 13 05-21-2010 07:56 PM
