Old 03-08-2011, 09:15 AM
klik's Avatar
klik klik is offline
Vehicle: 2013Dodge Ram Laramie Longhorn
Trim Level: Laramie/Longhorn
Color: Copperhead/White Gold
klik is on a distinguished road
Default Powerless Doors
as mentioned in the power window thread on another forum I have no power to any of the controls in the front doors - well now there is power to to control the rear door windows and the remote key fob will open and close the door locks. I'm totally bewildered - will a 25A fuse work in place of the CB1 & CB2 circuit breakers (a person has no way of knowing if they are good or not by looking at them) DESPERATELY NEED HELP
Old 03-10-2011, 07:32 AM
Al E. Gator's Avatar
Al E. Gator Al E. Gator is offline
Vehicle: 2014 Ram 1500
Color: Deep Water Blue Pearl
Rep:30
Al E. Gator is on a distinguished road
Chances of the breakers being bad is about 1:1,000,000. If you want to confirm they are good either buy or find someone who has an ohmmeter. Disconnect your battery and measure across the terminals of each breaker. A good/untripped breaker will read near 0 ohms, a bad one will measure somewhere from 1 Million ohms to infinity. Looking at your location I understand that you might be a long way from a dealer, but replacing breakers with fuses on a new truck is generally a bad idea. If I understand the description of your problem, it sounds like nothing worked before and now some things work. If that's the case, I would check for a bad wire between the door and the chassis where it flexs when you open and close the door. The next place I would look is at the switch block itself.
Old 03-10-2011, 08:51 AM
klik's Avatar
Thanks for the info but after letting the dealer have it for a day it turned out to be a fuse after all - great thing was there was no charge
Old 03-11-2011, 07:20 AM
Rep:30
Good to hear. From you previous post I thought maybe you were +100 miles from the dealer.
98 + wiring diagram for doors mlrtym Electrical 0 07-23-2010 06:19 PM
5x7 6x8 in front doors? olsarge Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 05-03-2010 12:19 AM
New here an got a question bout my doors? dirty97ram Newbie Checkin! 10 01-29-2010 05:35 PM
Unlocking doors marineman Dodge Ram General Discussion 1 01-27-2010 05:12 PM
Remote not unlocking doors? Big Daddy 2009 Dodge Ram Forum 5 01-26-2010 07:32 PM
