Old 03-08-2011, 11:53 AM
MarkThomas's Avatar
MarkThomas MarkThomas is offline
Vehicle: 2014 Dodge Ram Crew Cab
Color: Maximum Steel Metallic
MarkThomas is on a distinguished road
Default 2011 4x4 Big Horn Leveling
Ok, I have read every post on here regarding level kits. My head hurts
Anyway, I want to do a simple level on my 2011 that requires no upgrade to wheels, tires, or shocks...just want to install a leveling kit, have the truck aligned, and head off on my truck-rides-like-stock-but-looks-better way.
Have read good things about Hell Bent, but since they are steel, will I have ride issues? Since Daystar is not steel, would that be the best way to go?
Or, can I just do a torsion bar adjustment to get an extra 1.5" height in the front?
Don't sell yourself short Judge, you're a tremendous slouch.
Old 05-19-2011, 08:38 PM
Rep:1625
MarkThomas, you have a PM answering your question.
Old 05-20-2011, 11:34 PM
Bigboyky Bigboyky is offline
Vehicle: 2011 Ram 1500
Trim Level: Laramie Monotone
Color: Mineral Grey Mettalic
Bigboyky is on a distinguished road
Well that's not fair.... I really wanted the answer too!
Old 05-21-2011, 08:13 AM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
if your truck is a 4X4, you will not have any torsion bars..... For my 4X4 I went with DayStar, no issues, good product, rides just like factory
So it is written ! So it shall be done!
Old 05-21-2011, 05:37 PM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
If you can find them I would get bilstein 5100 struts. They adjust up to 2.8" and they ride great. I know because i have a set on my truck .
Old 05-21-2011, 08:28 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Well for others who may be looking at this thread for answers...
Your 2011 has coilover IFS and does not have torsion bars. 4x4s can have torsion bars, I believe 02-05 Ram 1500 had torsion bars in the front.
Alot of people will argue about the steel on steel with the HBS and other steel spacers but there is a rubber isolater that goes between the spring and spacer so it's not true. Ride quality is pretty comparable to stock, a little stiffer because you limit wheel travel.
I have to say I have heard more complaints about Daystar spacers then I have good things. I have actually seen several people who werent happy with there stance with the Daystar level switch to HBS spacers and were happy with the results (if you search there are even a few threads on the forumz)
Its almost the same process to install a spacer on your 1500 as it is to install adjustable shocks.
For some reason Bilstiens are only listed as up to 2.5" for 2011 although it used to be 2.8"
It really comes down to what your looking to spend. Bilstiens are probably the best route to go but they are hard to find. There are also other companies the make adjustable shocks. If you still set on just a leveling kit and not replacing the shocks with a adjustable strut then I would definitly recomend the HBS spacer.
Old 08-14-2011, 09:03 PM
Chris11Ram's Avatar
Chris11Ram Chris11Ram is offline
Vehicle: 2011 Dodge Ram
Chris11Ram is on a distinguished road
On a 2011 4x4 do we have shocks or struts on the front? And if you change to bilstiens do you have to have a front end aliment?
Old 08-14-2011, 09:15 PM
bombadillo's Avatar
bombadillo bombadillo is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Rep:25
bombadillo is on a distinguished road
Daystar 2.5" front, 1.5" rear leveling kit. Everything else is stock on it with the exception of the new wheels but the factory tires were kept. NOTHING else made it any higher or I would have done it
Sorry I know its on different sides, but you get the idea. Made a huge difference to me and when I go and park it at the dodge dealership next to a standard SLT or ST, it looks MUCH better.
2011 4.7L with AVS ventshades, Vision 375 Warrior wheels, Daystar 2.5" leveling kit, GTS Blackout taillights. Magnaflow exhaust done custom, (sounds AWESOME) and I'm sure more to come.
Old 08-15-2011, 02:22 AM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
im gonna recomend the bilstein 5100's aswell i just recently installed on mine and they are great
Old 08-29-2011, 03:05 AM
AzHunter's Avatar
AzHunter AzHunter is offline
Vehicle: 2006 Dodge Ram Quad Cab 4x4
Trim Level: LARAMIE QQ 4x4 3.92
Rep:52
AzHunter will become famous soon enough
What is so great about the bilstein 5100's? What is the compairable difference between the adjustable strut and a leveling kit? I am interested because the leveling kit is the next thing I want to do.
If i can kill it with an arrow, I'll eat it.
Window Vents for 2011 Big Horn? FormerChevyGuy 2011 Dodge Ram Forum 23 01-19-2011 02:14 AM
2011 ? on is to much vibration after leveling kit install 2011 ram 1500 4wd Hemi11 Newbie Checkin! 10 01-12-2011 03:28 PM
Installed Rough Country 2.5"? Leveling kit 2011 Casper Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 16 01-02-2011 06:29 PM
Best option for leveling my 2011 sport Zerox Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 11-28-2010 02:03 AM
2011 Big Horn and Outdoorsman RootBeer 2011 Dodge Ram Forum 6 10-21-2010 12:45 AM
