Old 09-19-2011, 12:15 AM
AzHunter's Avatar
AzHunter AzHunter is offline
Vehicle: 2006 Dodge Ram Quad Cab 4x4
Trim Level: LARAMIE QQ 4x4 3.92
Rep:52
AzHunter will become famous soon enough
Originally Posted by nysharkbait View Post
Ok. So does anybody have a profile picture of their vehicle with JUST the bilstein's on them?
Spent $210 after taxes for the shocks and $80 on the alignment. Put them in myself with the help from a friend in about 2 1/2 - 3 hours.
Before and after just the 5100's set at 2.1 Inch lift.
After
If i can kill it with an arrow, I'll eat it.
Old 09-19-2011, 12:21 AM
AzHunter's Avatar
Rep:52
After having my Bilsteins on for a couple of weeks now, It think it rides nicer and absorbs the speed bumps/humps and bumps in the road better. I am going to pick up the ones for the rear next.
Old 09-19-2011, 12:35 AM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
The 5100's are awesome!! I was thinking of going with a set for my rear but BDS had Fox shocks made for the BDS lift. I will be buying them instead .
Old 09-19-2011, 08:34 AM
MarkThomas's Avatar
MarkThomas MarkThomas is offline
Vehicle: 2011 Dodge Ram Crew Cab
MarkThomas is on a distinguished road
So, with just a set of front 5100s on my 2011, will I get the death wobble?
Also, what size tires can be put on the stock rims with the 5100s?
With truck "level", will the back droop when I hook up to my boat?
So many options with pro/cons I am having a real hard time deciding. 5100s seem like a much better option than a spacer-type level, but the fear of the death wobble has me concerned.
Thanks!
Don't sell yourself short Judge, you're a tremendous slouch.
Old 09-19-2011, 11:32 AM
AzHunter's Avatar
Rep:52
The Famed "Death Wobble" was a wobble of the front suspension at high speeds when hitting a bump or something in the road. This is not an issue with typical leveling kits including the 5100's. The only vibration that people have been experiencing is a vibration at lower speeds in 4wd only. Not all people are experiencing this, only some.
I just put a set of the 5100's last weekend and I do not have any vibration at all. I have ran 2wd and 4wd at all speeds and have no issues. I think it is the minority that has the vibration and not the majority. In fact it rides better than stock IMO.
I hear that you can run 35X12.5's MAX with the shocks set at their max of 2.8" lift. If you only go the 2.1", I would suggest 33's
Yes the back of your truck will squat a little after you hook up anything to the hitch. It all depends on what your doing. If you just have a boat your hauling with 300 lbs of weight on the hitch, not bad. I have my 5100's set at 2.1" lift and I have 1 1/4" rake. This will allow me to haul my quad trailer and boats with the truck sitting relatively level. If I hook up a travel trailer or toy hauler with 500-800lb hitch weight, expect it to squat and be nose high quite a bit. If that bothers you, pick up a set of air bags for your rear coils. You can air them up when hauling and deflate them when not to maintain your ride comfort. That and you can get them for only $100. Cheap MOD for something that can help in so many ways.
Old 09-20-2011, 09:06 AM
RAM1500S RAM1500S is offline
Vehicle: 09 ram 1500 sport
Trim Level: sport
Rep:50
RAM1500S will become famous soon enough
looks good I wonder how it will look with 2.8
Old 09-20-2011, 10:01 AM
thiggins's Avatar
thiggins thiggins is offline
Vehicle: 2012 Ford F150
Rep:44
thiggins is on a distinguished road
Looks awesome. Can't wait to raise my truck's front end also.
Old 09-20-2011, 10:33 AM
MarkThomas's Avatar
Will running a spacer level or 5100s void any warranty?
Old 09-20-2011, 11:42 AM
thiggins's Avatar
Rep:44
If they think whatever problem is related to the lift, they might deny a warranty claim.
This is one reason I'm going with spacers; I can install and remove them easily, well, "easier" than shocks anyway.
Of course, they can't deny something unrelated to the lift. But that gets interesting. Say I lifted the front only,
but I develop a differential whine (which I have), can they deny the diff repair under warranty by saying
the front "level" lift caused a diff problem due to a slight angle change in the rear ?
Old 09-20-2011, 02:28 PM
MarkThomas's Avatar
And can you achieve a "level" with JUST a set of front 5100s or do they have to be used with something else?
*nevermind* I see from AZs truck that, yes, you can.
Window Vents for 2011 Big Horn? FormerChevyGuy 2011 Dodge Ram Forum 23 01-19-2011 01:14 AM
2011 ? on is to much vibration after leveling kit install 2011 ram 1500 4wd Hemi11 Newbie Checkin! 10 01-12-2011 02:28 PM
Installed Rough Country 2.5"? Leveling kit 2011 Casper Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 16 01-02-2011 05:29 PM
Best option for leveling my 2011 sport Zerox Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 11-28-2010 01:03 AM
2011 Big Horn and Outdoorsman RootBeer 2011 Dodge Ram Forum 6 10-20-2010 11:45 PM
