2011 4x4 Big Horn Leveling - Page 4 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-20-2011, 04:59 PM
AzHunter's Avatar
AzHunter AzHunter is offline
Vehicle: 2014 Ram Crew Cab 4x4
Trim Level: BigHorn CQ 4x4 3.92
Color: Deep Cherry Red Crystal
Rep:52
AzHunter will become famous soon enough
Originally Posted by MarkThomas View Post
And can you achieve a "level" with JUST a set of front 5100s or do they have to be used with something else?
*nevermind* I see from AZs truck that, yes, you can.
I still have a 1 1/4" rake with them set at 2.1". If I had them at 2.8" it would be closer to 1/2" - 3/4" rake. That's about as level as you can get IMO.
If i can kill it with an arrow, I'll eat it.
Old 09-22-2011, 10:00 AM
MarkThomas's Avatar
MarkThomas MarkThomas is offline
Vehicle: 2014 Dodge Ram Crew Cab
Color: Maximum Steel Metallic
MarkThomas is on a distinguished road
Anyone know what size tires I could run with a set of Bilstein 5100s in the front and stock 20" rims? I don't wanna stuff the well, but don't want tiny tires, either...
Thanks!
Don't sell yourself short Judge, you're a tremendous slouch.
Old 09-22-2011, 02:20 PM
Porter_'s Avatar
Porter_ Porter_ is offline
Vehicle: 2011 Ram 1500 4x4
Rep:39
Porter_ is on a distinguished road
Thanks!
35's look stuffed with only a leveling kit IMO. i'd stick with 33's and go with a wider tire than stock. just one man's opinion, it's all personal preference. to answer your question: i believe with the Bilstein's set at 2.8" you can fit 35's. the width is the issue with stock 20's. which 20's do you have chrome clad or painted aluminum? if you have the chrome clads and want a 12.50" wide tire you may need to look for one that runs narrow to avoid rubbing your UCA's; say around 12.2" wide.
2011 Ram 1500 Big Horn 4x4 5.7L
1.5" TGC Leveling Kit, 305/55/20 Toyo Open Country A/T's
Old 09-22-2011, 02:40 PM
MarkThomas's Avatar
Thanks for the reply...I have the painted ones, not chrome.
Old 09-22-2011, 02:46 PM
Porter_'s Avatar
Rep:39
in that case, here's the clearance i have with the same wheels and 305/55/20 tires listed as 12.4" wide on Toyo's website. should give you a point of reference to work with.
Old 09-22-2011, 03:29 PM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
You can get different rims with a -offset to bring the tires out. Or you can use wheel spacers.
Old 09-22-2011, 03:38 PM
Porter_'s Avatar
Rep:39
i figured that went without saying.
that's a personal choice but after looking into wheel spacers i decided against ever using them (turns out i didn't need them anyway).
Old 09-23-2011, 10:40 AM
MarkThomas's Avatar
Thanks for the info, Porter! And yeah, aftermarket rims aren't an option...I like the stock ones and do not want to spend another $1k on rims.
Window Vents for 2011 Big Horn? FormerChevyGuy 2011 Dodge Ram Forum 23 01-19-2011 02:14 AM
2011 ? on is to much vibration after leveling kit install 2011 ram 1500 4wd Hemi11 Newbie Checkin! 10 01-12-2011 03:28 PM
Installed Rough Country 2.5"? Leveling kit 2011 Casper Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 16 01-02-2011 06:29 PM
Best option for leveling my 2011 sport Zerox Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 11-28-2010 02:03 AM
2011 Big Horn and Outdoorsman RootBeer 2011 Dodge Ram Forum 6 10-20-2010 11:45 PM
