Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 03-08-2011, 12:08 PM
danmitch33 danmitch33 is offline
Vehicle: 2004 reg cab
danmitch33 is on a distinguished road
Default help me lift and level my 2wd
I have a 2004 2wd reg cab and am looking to get a 3 inch lift. I don't know much about the kits but are there kits that will level and lift at the same time? like 5 in front 3 back or something? any help would be great. everything is stock on the truck. Also would i have any trouble fitting 35s ? I've done some research and it's looking like i'll be ok. any opinions?
Old 03-09-2011, 12:31 PM
danv802008's Avatar
danv802008 danv802008 is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: ST 4x4
Rep:53
danv802008 will become famous soon enough
So leveling kits will either provide you with enough lift to level your front with your rear or depending on the height of the front lift may come with a smaller spacer for the rear also.
The only levling kits i'm seeing online for an 04 2wd are 1.5 and 2 inch, which i don't think would allow you to run 35's. I do see some 3 inch body lifts but i still don't think you would be able to run 35's with that.
You might try calling a local off road shop or the folks at 4wheelparts.com and see if they can find something for you.
MODS List: Pro Comp 6" Suspension Lift | Nitto Dune Grapplers 35's | Moto Metal Skull Wheels | Flowmaster 50 Series HD SI/DO | AFE Stage 2 Pro 5 CAI | HyperTech Performance Tuned
level vs lift donn12 5.7L (345 cu in) HEMI V8 Specific Topics 9 01-11-2011 12:12 PM
305/60R18 and 2" lift or level kit... pault Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 12-15-2010 05:23 AM
Level kit on lift kit problems? martinjoa Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 07-02-2010 09:29 PM
26" KMC Rims on 2008 Ram 2" level lift or 2" level drop Steven Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 20 02-03-2010 02:36 PM
lift or level sean Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 07-01-2009 07:30 PM
