Old 03-08-2011, 12:44 PM
Tominator223 Tominator223 is offline
Tominator223 is on a distinguished road
Default a/c does'nt blow cold @ idle/not low on refridgerant
my a/c on my 04 qcab hemi is not low on 134a . but blow s warmer air @ idle? and i was told low presure switch could be problem, but its in the compresor . and i will have to change the whole thing & not just the switch. anybody else have similar problem or know if this is the case?i would hate changing compresor & it was only a $10 switch. or somthing else
Old 03-08-2011, 12:49 PM
Rep:1885
If it's cooling while moving and not while sitting, it's most likely a condensor fan problem.
Old 06-01-2011, 01:16 AM
dodge87 dodge87 is offline
Vehicle: 02 ram 1500
Color: gold
dodge87 is on a distinguished road
yeah there should be a little rubber plug under there its for acc. look to see if it has fallen out.
sorry that was ment for another my bad but i'm glade i messed up and sent this to you because i have a 02 that is doing that same thing also
Old 06-01-2011, 03:36 PM
Cubanu Cubanu is offline
Vehicle: 2003 Ram 1500
Trim Level: Quad sport slt
Color: Dark Gray
Cubanu is on a distinguished road
The same thing is happening with my truck. What my is doing is at idle you hear the compressor kick on and off every few seconds. I was thinking it could be that I was low on 134 but now reading this it's making me wonder. Another problem is that if I'm going slow like 5 mph it feels like the truck is hesitating and then it's fine like I said every few seconds. I'm guessing that problem is probably do to the compressor kicking on and of like that. If you find a solution let me know and I'll do the same. It's 92 here in jersey today and I hope it's a smooth quick ride home AC works beautifully at highway speeds
Old 06-02-2011, 09:55 AM
Color: Dark Gray
Well I did some probing yesterday and whip out my test light sure enough I'm getting power to my fan but it's not kicking on. Gonna order the piece today RamTech is the man. Keep you guys informed once install to see if it fully fixes the situation. Once again thanks RamTech.
Old 06-07-2011, 06:27 AM
marcf11 marcf11 is offline
Vehicle: 2003 Dodge Ram
Color: Blue
marcf11 is on a distinguished road
how hard is it to change that condensor fan? mine is doing the same thing.
Old 06-13-2011, 01:50 PM
SFA1500's Avatar
SFA1500 SFA1500 is offline
Vehicle: 2002 Dodge Ram
Color: Blue
Rep:22
SFA1500 is on a distinguished road
Search it on youtube and there is a video of how to replace it yourself!
Old 08-28-2011, 05:10 PM
AcombativePYRO's Avatar
AcombativePYRO AcombativePYRO is offline
Vehicle: 2003 Dodge Ram 1500 4.7v8 SLT
Color: SILVER
AcombativePYRO is on a distinguished road
Does anyone think that this might have something to do with overheating as far as engine coolant goes? My truck is doing the same thing and my engine temp rises alot and then comes down. But usually good and normal while moving. any ideas?
[IMG]http://i130.photobucket.com/albums/p270/firepyro11/2002%20Dodge%20Ram/RAM1.png[/IMG]
Old 09-15-2011, 09:50 PM
kmdracer's Avatar
kmdracer kmdracer is offline
Vehicle: 03 Ram QC , 08 CSRT4
Rep:43
kmdracer is on a distinguished road
I don't really see how it could be related, as the condenser fan is electrical, and your coolant fan is clutch driven. Perhaps your fan clutch is bad and not spinning you radiator fan properly so that your truck coolant heats up at idle?
Oh and to the OP, I had the identical problem a few years ago. It was definitely the condenser fan. It wasn't all that hard to replace as I recall.
Cold draft from under the seat? wjsamx 2010 Dodge Ram Forum 29 09-03-2012 12:28 PM
A/c does not want to blow hard just cold olsarge Heating & Cooling 33 09-28-2011 01:12 AM
Remote starter quits in cold weather FDBDW 2009 Dodge Ram Forum 16 02-08-2011 12:29 PM
hot or cold darnold76 Heating & Cooling 2 12-20-2010 09:41 PM
Cold air intake bones64 Dodge Ram General Discussion 12 10-12-2009 02:51 PM
