Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 03-08-2011, 02:16 PM
tjcole tjcole is offline
Vehicle: 2007 Ram
tjcole is on a distinguished road
Default Towing wiring issues 2007, 1500
I have a 2007 Ram 1500 with the factory towing package.
I just bought a travel trailer and when the RV dealer went to test the lights on their little tester, it is showing that whenever I turn on the left turn signal, the backup lights also blink.
We tested this tester on some other trucks at the dealer parking lot (other dodge rams) and they tested out just fine. We hooked up the travel trailer and it did the same thing the tester was doing
I disconnected the towing brake so there is nothing plugged into the system that is not factory. I went over every inch of the wiring that is visible and I see no rodent damage or any other abrasions.
At the moment I have it at the dealer but they are proving to be incompetent.
The dealer says they tested all the leads for correct voltage and they seem fine. The issue is there seems to be a short and the left turn signal is also activating the backup lights causing them to blink as well. weird.
Does anyone have any ideas or experience with this phenomenon?
Thank you,
Todd Cole
"There are 10 types of people in this world, those who know binary and those who don't."
Old 03-08-2011, 09:44 PM
Rep:1877
If the wiring checks out good then the TIPM is the most likely culprit.
Old 03-17-2011, 12:45 AM
Vehicle: 2007 Ram
Ok I found out what happened.
It only took three trips to the Dodge dealer...
It appears that there is a connector somewhere in the electrical wiring for towing brakes and the other wires. Well the dealer found that the factory never physically connected the wires. So they connected them and now it all works great.
Hope this helps someone else.
Thank you,
Old 03-17-2011, 02:33 PM
wylie wylie is offline
Vehicle: 2011 Dodge Laramie 1500 CC
Color: Blue
Rep:55
wylie will become famous soon enough
What is amazing about your 2007 is that the problem has existed the whole time you have had the truck. How did it pass state inspection for 5 years in a row without someone seeing that problem??????
Old 03-17-2011, 02:46 PM
Rep:1877
Do they check trailer light hookups during the inspections?
Old 03-18-2011, 05:57 PM
Vehicle: 2007 Ram
We don't have state inspections. Just have to buy our tabs once a year and thats it.
I've never towed anything other than a 4-wire boat trailer (worked just fine) but when the RV dealer tested the 7-pin, thats when the problem was discovered.
Thank you for the help.
Dodge 1500 not good for towing as advertised. TheDon 2010 Dodge Ram Forum 34 12-30-2010 12:36 PM
2002 Ram 1500 Wheel issues larrymr Newbie Checkin! 10 12-19-2010 12:29 PM
Heavy Duty towing mirrors on 1500 1BadassHemi Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 23 12-18-2010 01:36 PM
2007 Dodge Ram 1500 Cab Lights TrueJarhead11 Custom Dodge Ram Interior and Exterior Lighting 12 11-24-2010 10:15 AM
Slip on towing mirrors for 09 RAM 1500 chris66 2009 Dodge Ram Forum 0 06-23-2009 03:47 PM
