MOPAR DECALS
Old 03-08-2011, 03:16 PM
MarkThomas's Avatar
MarkThomas MarkThomas is offline
Vehicle: 2014 Dodge Ram Crew Cab
Color: Maximum Steel Metallic
MarkThomas is on a distinguished road
Default Mud flaps for a 2011
So, went into my local truck accessory shop to see about getting some flaps on my 2011 Ram. Guy that runs the shop has a 2010 Ram, so his first thought was the Weather Tech flaps.
So I ask him, do they install over the black plastic that is already in the wheel well, or do you remove the plastic first. He got a puzzled look on his face as went from his truck over to mine.
Long story short, he called 3 of his suppliers...Weather Tech, Husky, and one other and none of them have flaps to work with the (apparently new for 2011) plastic piece on the wheel well.
Anyone here have a 2011 with the black plastic piece on the bottom of the well? Have you found a flap to fit? I would actually prefer a flat flap so I don;t get any chaffing or water/gunk trapped in the contoured ones.
Don't sell yourself short Judge, you're a tremendous slouch.
Old 03-08-2011, 03:28 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1230
There isnt one. Only solution is to cut, or remove the plastic piece. I have a set of mopar flaps. they go in place of the plastic, and work quite well.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 03-08-2011, 03:34 PM
bigtom225 bigtom225 is offline
Vehicle: 2014 Ram 1500
Rep:24
bigtom225 is on a distinguished road
Dittto, here I put the Mopar mud guards on my 2011 Sport. The plastic pieces are removed but the guards cover it up and it looks great.
Old 03-08-2011, 03:43 PM
MarkThomas's Avatar
Did you guys install those yourself? Are they a no-drill flap?
Have the part #?
Thanks!
Old 03-08-2011, 05:01 PM
ArmyofOne's Avatar
US Army Retired
Rep:1230
I DIY'd, Part number for OEM flaps (the ones that fit on standard rams, if you have factory fender flares these wont fit): 82212287
82212210 will not fit standard rams, only the ones with flares.
here is my How-to:
http://www.ramforumz.com/showthread....125#post465125.
took me 20 mins to install both. Worth the $45. I did not drill, its optional, the way I see it.
Old 03-08-2011, 05:17 PM
Rep:2875
I found this site yesterday, mud guards are under exterior
loads of goodies on the site
http://www.mopar.com/accessories/ram_accessories
Old 03-08-2011, 07:08 PM
cudase's Avatar
cudase cudase is offline
Vehicle: 2011 Dodge Ram
Trim Level: Sport Crew Cab
Color: Mineral Gray Metallic
Rep:53
cudase will become famous soon enough
Weather techs fit fine over the pieces of plastic, but they are the contoured ones. Flat or not, you are going to get stuff trapped between the body and flap. They are contoured to over the plastic piece. No drilling required.
Old 03-08-2011, 07:49 PM
M.Scipione's Avatar
M.Scipione M.Scipione is offline
Vehicle: 2011 Ram 1500 Crew
Rep:41
M.Scipione is on a distinguished road
I have the molded mopar flaps as well and they really look great.
As for as drilling is concerned , the rear flaps really dont require the hole to be drilled out because it is between 2 other screws that secure the flap into the wheel well. (I drilled it anyway)
The front flaps really should be drilled and screwed because that hole is located all the way at the top edge of the flap, without this screw the molded plastic can gap away from the fender.
edit: see the PDF installation guide for the front flaps here http://www.mopar-accessories.com/en-...=3163&pc=64701
Old 03-08-2011, 08:15 PM
alharm1's Avatar
alharm1 alharm1 is offline
Vehicle: 2011 Ram
alharm1 is on a distinguished road
I have the weathertech no drill mud flaps. I had no install issues, and they look good.
Old 03-08-2011, 08:44 PM
FireWire's Avatar
FireWire FireWire is offline
Rep:12
FireWire is on a distinguished road
I bought the Mopar flaps.
They look like they are meant for the truck (because they are)
The dealer installed them for free for me (bonus)
Jeff
2011 Exhaust Mod Question uncletony76 2011 Dodge Ram Forum 10 06-27-2012 08:54 PM
2011 Ram 1500 advice before buying airborne89 2011 Dodge Ram Forum 32 06-25-2011 12:34 PM
2011 Mygig in 2010 Ram RootBeer Custom Dodge Ram Interior Modifications - Custom Audio / Video 8 09-10-2010 11:10 PM
2011 Ram 3500 Mud Flaps ingaasher09 LD RAM - General Discussion 6 09-05-2010 01:32 AM
