Old 03-08-2011, 10:18 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
If I understand correctly the hose is too small for the fitting? What I do is take a pair of large needle nose pliers or any cone shaped device you have handy. Shove that in to the hose as hard and as far as you can and let sit for a day or so. Heat it up a little and shove in harder and farther. This was you spread the opening a bit and when you are ready to install you jank it out and slip it over the opening you need it to go onto. You may also try to slip on a little oil on the inner part of the hose so it will slide on more easily.
www.beatcraigslist.com - for posting dangers & secrets
Old 03-09-2011, 10:45 AM
dgard61's Avatar
dgard61 dgard61 is offline
Vehicle: 2010 Ram Crew Cab, 4x4 Laramie
Color: Inferno Red/Sandstone
Rep:91
dgard61 will become famous soon enough
Originally Posted by Pull Ya View Post
I ordered a BT Catch Can and the braided lines. Can anyone give me the secret to installing the braided line on the PVC valve and the Throttle Body. The braided line fits the fittings on the catch can perfectly however the lines appear to be too small for the PVC and Throttle body. I've tried grease, putting the ends in boiling water, pushing, pulling, twisting ,cussing, bleeding, etc etc-----all with no luck. Any suggestions would be appreciated.
Jay
Had the same problem see thread http://www.ramforumz.com/showthread....350#post348350. I also did the needle nose plier trick stretching the hose. Only got them on 80% -90% of the way on. Have had no problem with them coming off.
Vent Visor's, Bug Deflector, Chrome Fuel Door, Bak Flip G2 Tonneau Cover, Bed Extender, EZ Down Tailgate Dampener, Line X Spray in Box Liner, WeatherTech Winter Mats, Husky Moulded Mud Flaps, Billet Tech Oil Catch Can, 12" S/S Antenna Mast, Chrome T/G Handle, Mopar CAI, Painted Engine Cover, Billet Tech Polished Underhood Cap's, Front Window Tint, Billet Hitch Cover, Anti-Theft Valve Cap's, MGP Caliper Covers, Retractable S/S Stake Pocket Anchors, Mopar Trailer Brake Controller, Recon LED Light Bar, Polished Billet Lock Pins, Mopar S/S Door Sills, Interior LED's, Mopar LED Cargo Bed Lights, Billet Throttle Body Cover
Old 03-09-2011, 10:50 AM
vided vided is offline
Vehicle: 2010 ram quadcab
Trim Level: slt,big horn,bucket
Rep:22
vided is on a distinguished road
If you want a before picture, go out and open the hood of your truck and if you don't have a catch can, that is the before picture. If I don't get this figured out it might also be the after picture.
Jay
mikey likes it!!!!!!!
Old 03-09-2011, 11:33 AM
Pull Ya's Avatar
Pull Ya Pull Ya is online now
Vehicle: 2013 Dodge Ram Laramie 4x4
Rep:365
Pull Ya is just really nicePull Ya is just really nicePull Ya is just really nicePull Ya is just really nice
dgard-I saw your thread before and was using it as a go-by(Thanks for the step by step explaination) so I knew I was going to have a little trouble but hell-----I've got two needle nose plyers stuck in the end of the hoses now and I'll wait till later today and try it again. Did you use the small billet covers on the ends of the hose for the PCV and the throttle body or did you put a small screww clamp on the hoses once you got them on--or almost on? I thought a clamp might work and you couldn't see it anyway because it would be covered by the engine cover.
Jay
Just cause it's loud doesn't mean it's fast and just cause it's shiney doesn't mean it's protected.
Semper Fi Forever
Old 03-09-2011, 12:43 PM
dgard61's Avatar
Rep:91
Jay
Glad I could help with the write up. I used the billet covers. As I mentioned only got them on about 80 - 90% of the way. It was a real B**ch to get them on that far. When it get's a little warmer here i'm thinking of cutting the original tubing, heating the ends and flaring them somewhat.Then reinstalling the braided hoses on the ends of the original tube. Good Luck!
I actually checked mine in Feb. They haven't moved.
catch can for 07 5.7 brusk Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 32 08-22-2014 02:20 PM
Catch Can - Worth it? Ram15002ndgen Dodge Ram General Discussion 13 01-29-2011 07:22 PM
BEWARE whom ever has catch can cold weather mineralram 5.7L (345 cu in) HEMI V8 Specific Topics 17 01-01-2011 09:01 PM
Catch can install? Gron86 2009 Dodge Ram Forum 27 12-07-2010 01:22 PM
Katzkins Leather Seat Upgrade Installation Write-Up Part 1 DoubleARS Custom Dodge Ram Interior Modifications - Custom Audio / Video 0 11-29-2010 09:19 PM
