tonneaucovered.com
Old 03-08-2011, 04:40 PM
bamasport's Avatar
bamasport bamasport is offline
Vehicle: 2010 Dodge Ram 1500 Crew 4X4
Color: deep water blue pearl
Rep:186
bamasport has a spectacular aura aboutbamasport has a spectacular aura about
Default calling all 2008's with leveling kit or lift kit
I have been a forum member here for a little while now and own a 2010 dodge ram sport.
My older brother just purchased a 2008 big horn 4wd, traded in his ford after seeing my truck, i consider that a win in my book! since he doesnt have the time to get onto a computer, i thought i would help him out and ask members here what is the best leveling/lift kit for a 2008.
what are the problems you have or have had? how is the ride? leveling shocks? pics? anything pertaining to a 2008 4WD Dodge Ram lifted or leveled would be great.
3.92 rear axle, OEM 20" rims, 20% tint, Mopar wheel-to-wheel side steps, K&N drop-in air filter, LineX bedliner, OEM Tow hooks, Rampage Tailgate Light Bar, Borla Cat Back, 6" BDS lift, 35x12.50x20 Nitto trail grapplers, Custom painted interior, dodge slush mats
JON
Old 03-08-2011, 07:59 PM
Muddbog's Avatar
Muddbog Muddbog is offline
Vehicle: 2007 Dodge Mega Cab 4x4
Color: 2 Tone Blue/Silver
Rep:20
Muddbog is on a distinguished road
Send a message via Yahoo to Muddbog Send a message via Skype™ to Muddbog
I just installed a set of Firestone Level-Rite Air shocks last night because I just bought a new Western MVP Plus 8'6" V-Plow that weighs about 1000 pounds. I am sold on these shocks. If you want to be able to carry more weight in the front these are the easiest fix. They aren't cheap though. I got mine at etrailers.com for $489 which is the cheapest I could find. They are basically a Bilstein Shock with a compact air spring. They are the best out there from what I've heard. I am a huge fan of bags so my opinion may be a little biased. The ride is great! I think it is alot better than it was with the stock shocks. I will post pictures tomorrow.
I am going to add the Firestone Ride-Rite Bags in the rear with the on-board Air management system, Gauges, rocker switches, 3 Gal air tank which will be mounted under the truck on the frame. Also there will be 2 spots to hook up an Air hose on the front and back concealed. Just some Ideas for you.
If you do get these "DO NOT" compress the shocks more than 1" prior to installation you risk messing up the Bags. I got lucky!
2007 Dodge Mega Cab 4x4 5.7 Hemi
Old 03-08-2011, 08:15 PM
sk8noregon's Avatar
sk8noregon sk8noregon is offline
Vehicle: 2008 Dodge Ram
Rep:637
sk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to all
Mine is leveled but unsure of the brand. Ride is a little stiff but I still have factory shocks on.
"Rocky and Bullwinkle"
Join the "Mineral Gray Metallic Ramz Group" here !
Old 03-08-2011, 09:21 PM
bamasport's Avatar
Rep:186
Any other 08's out there will a leveling/lift kit. complaints or raves are welcome. just trying to get some info from a bunch of people.
JON
Old 03-09-2011, 11:57 AM
Muddbog's Avatar
Rep:20
As promised here are some pictures before and after the Level-Rite Air Shocks
This is before but the plow was not raised. When it is up it would rest on the bump stops.
This is after.
That is with 16.5 PSI in each side.
Old 03-09-2011, 12:06 PM
CapperRAM's Avatar
CapperRAM CapperRAM is offline
Vehicle: 2013 RAM Power Wagon
Trim Level: Power Wagon
Rep:205
CapperRAM has a spectacular aura aboutCapperRAM has a spectacular aura aboutCapperRAM has a spectacular aura about
Here's the link to my level kit install...
http://www.ramforumz.com/showthread....165#post278165
Muddbog's Avatar
Rep:20
What size are those Tires. How much of a lift is that?
Old 03-09-2011, 10:17 PM
ScatPak07's Avatar
Rep:970
Ok there is a big difference between a lift and level. This totally depends on what he wants to spend. If you want to just level it then use the Bilstein 5100s to do it. You get great shocks and a level all in one. Definitely the best way to level out the front of the truck.
If you want to lift the truck then go with a 6" since the 4" will cost pretty much the same. If you do lift it then go with Superlift, Fabtech or BDS since they are the best quality ones out there. Dont cheap out and go Rough or Tough Country. They dont even come with proper instructions, thats how cheap they are. Dont cheap out on parts for your truck, not a smart thing to do.
Old 03-11-2011, 12:58 AM
bamasport's Avatar
Rep:186
is that 2.5 in front and nothing in back or 1.5 in back?
I know there is a big difference, i guess what im looking for is what other people have done so i can give him his options. he had been told that with a leveling kit, while driving there is a wobble, ive never heard this unless you have a lift kit. Plus trying to find out what size tires he can fit. I've read 33x12.5x20's or so. I'm not sure how much he is looking to spend but he is jealous of my truck with a 6" lift on it so he may try to 1up me for all i know. lol hopefully he doesn't because I dont want to have to go that much higher on my lift
JON
bamasport's Avatar
Rep:186
anyone have before and after pics of the Bilstein 5100 shocks????
JON
2008, leveling kit, leveling shocks, lift kit, suspension leveling
leveling kit plus suspension lift Jerkbait Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 11 03-15-2011 02:47 PM
Leveling kit or lift black 11 2011 Dodge Ram Forum 4 03-09-2011 12:58 PM
Ready lift leveling kit/Shop dicking me around? moparmanicac Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 23 12-08-2010 11:32 AM
lift kit with a leveling kit? Coffey68 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 10-26-2010 09:03 PM
leveling lift FDBDW 2009 Dodge Ram Forum 2 08-21-2010 03:11 PM
