Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Old 03-12-2011, 08:36 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
Originally Posted by MarkThomas View Post
Are the rears this easy, too...just ordered a full set and really do not want to pay for install.
Rears are easier, IMO, dont have to remove the side steps for those.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-30k miles-BF Goodrich Rugged Terrain T/A, Mufflex Muffler Delete, Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist, Total Load Control, AVS Visors and Bug Shield, K&N Drop-In, XenonDepot 5000k LED Headlamps in factory projectors.
Old 03-13-2011, 03:44 AM
RAMTX's Avatar
RAMTX RAMTX is offline
Vehicle: 2015 Dodge Ram Crew Cab 4X4
Trim Level: Lone Star
Color: Bright Silver Metalic
Rep:110
RAMTX will become famous soon enoughRAMTX will become famous soon enough
nice mod, thanks for the pics.
__________________________________________________ ___________________
__________________________________________________ _____________________ K&N drop in Air Filter - Tonno Pro Tri-Fold Bed Cover
Old 03-14-2011, 06:08 PM
MarkThomas's Avatar
MarkThomas MarkThomas is offline
Vehicle: 2014 Dodge Ram Crew Cab
Color: Maximum Steel Metallic
MarkThomas is on a distinguished road
Threw a set of these on my 2011 today. Couple quick notes:
1) Overall, installation was pretty easy...definitely not worth paying the $80 to $120 labor I was quoted by two separate dealerships.
2) The rears are very easy to install. All factory holes since there is no need to drill the middle bolt the instructions say to add...seemed unnecessary to me.
3) The fronts were a bit trickier for two reasons:
a) Major hang up was the plastic expandable "nut" they provide does NOT fit into the factory hole located on the underside of the rocker panel. It looks like the "nut" was designed for an elongated hole but the truck has a small circular hole in it. To prevent drilling, I just bit the plastic "nut" to compress it a bit, and then used a hammer to tap it into place. Still not 100% secure, but certainly sufficient.
b) You do have to drill a hole for the top screw on the front flaps. I know Army said he did not have the balls to do so, but if you do not secure the top flap hole, the flap will flop around a bit, and it will end up causing more problems than it solves.
I couldn't believe all the sand, dirt, etc between the factory plastic (that I had to remove to install flaps) and the paint. My truck has less than 600 miles on it and has been washed four times!
I remember on my 2000 Ram, that when I sold it with less than 36,000 miles on it, one of the flap holes had already rusted out. Would have thought 11 more years of engineering would have brought improvements with regard to trapping water/debris against steel surfaces...but, in fact, my 2011 has many more plastic-meets-metal points where rusting is just a matter of time. That part really sucks.
Don't sell yourself short Judge, you're a tremendous slouch.
Old 01-14-2012, 04:09 PM
mybigredram mybigredram is offline
Vehicle: 2012 Dodge Ram 4X4
mybigredram is on a distinguished road
Those flaps really look great, been looking for something for my 2012 4X4.
Old 01-15-2012, 10:17 AM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
Nice write-up. I would add some paint protection film between the paint and the mud flap. Other than that, spot on!
Old 01-15-2012, 11:50 AM
Ram1500SCC's Avatar
Ram1500SCC Ram1500SCC is offline
Vehicle: 2013 Ram
Color: Copperhead Pearl
Rep:30
Ram1500SCC is on a distinguished road
I agree with the paint film. I used a 3M product from Walmart. Some kind of packing tape or something. Thick enough and strong enough to not have those annoying scrape marks.
Old 01-16-2012, 09:56 AM
ArmyofOne's Avatar
US Army Retired
Rep:1195
I ended up removing them about 500 miles later, and using 3m Adhesive trim tape (double sided) where the edges meet the paint. There was already some light damage where they had rubbed. Luckily it came right out with some Meguiar's ultimate compound and a 3" orbital with an orange pad.
US ARMY-RETIRED
MOPAR T-Shifter Handle Install marko7717 Dodge Ram Knowledge Base 45 02-03-2016 11:44 AM
MOPAR Cold Air Intake Install 2009/2010 MightyBlueRam Dodge Ram Knowledge Base 56 09-07-2014 03:30 PM
How to install Dodge factory tow hooks. Boomer8404 Dodge Ram General Discussion 4 02-08-2011 11:57 AM
How to install diablo DAYTONA81 Diablo Predator Questions & Info! 3 02-02-2011 12:33 AM
Mopar Parts numbers for Install Kit??? BigGirlToys Electrical 3 12-22-2010 01:55 PM
