Old 03-20-2011, 01:22 AM
Jacqson Jacqson is offline
Vehicle: 2011 Ram
Jacqson is on a distinguished road
under the plastic rail caps, Dodge left a extremely uneven rail, a bunch of recessed areas, holes, clips, etc, looks like crap, that is why they put on the plastic rail caps, i don't know why they didn't give us a smooth rail, maybe for mounting a camper or something
only way to fix it & make it look decent, is to buy metal rail caps, then you can have the over the rail spray done & it looks great
My Line-X guy said to remove the Rail Caps, spray the liner over the rail and then replace the railcaps, If you can't use the old ones, new ones are about $30.00 per side from Mopar. I want to put a Canopy on my box but I had a concern about movement of the factory rail cap on the rail, wearing away the paint. The idea was to remove the factory rail cap, spray the rail with Line-x, and then replace it, that way if the rail cap moves with the canopy on it, it can't wear away the paint because the rail is protected with the Line-X.
Ruptured Brake Line lwalper LD RAM - General Discussion 8 06-01-2013 10:12 AM
Brake Line Flaring How To RamTech Dodge Ram Knowledge Base 6 04-28-2013 11:13 PM
Recalls wjsamx Dodge Ram Recalls and TSB's. 4 02-18-2011 12:28 PM
broken gas line power ram 150 5.2L V8 Specific Topics 2 12-29-2010 07:21 PM
Fuel line woes 1sthound LD RAM - General Discussion 0 08-11-2010 07:06 PM
