Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 03-08-2011, 09:41 PM
RAM1961 RAM1961 is offline
Vehicle: 2000 RAM 2500 V-10 Quad 4WD
Trim Level: SLT Laramie
Color: Maroon
RAM1961 is on a distinguished road
Default Towing in OD or 3rd with auto trans?
I'll be pulling a 16' double axle trailer - I'm not sure what the weight of it is...I would guess 1500#. Will be hauling approx. 3200# on top of that. Truck is '00 RAM 2500 V-10 auto with OD. The trip with the load will be 1100 miles. Is it recommended to tow with tranny out of OD or am I safe to run it in OD? Not sure of final ratio - either 3.73 or 3.5(?).
Old 03-08-2011, 11:39 PM
BigThirsty's Avatar
BigThirsty BigThirsty is offline
Vehicle: 2004 Dodge Ram 2500 4X4
BigThirsty is on a distinguished road
Let the truck tell you. If you hunt gears, go to a lower one. With the V-10 you shouldn't have much of a problem with that weight.
Me personally I wouldn't tow past 4th but then I don't know what gears your tranny has.
2004 Dodge Ram 2500 4X4 5.7
Old 03-09-2011, 12:01 AM
HawkFan1's Avatar
HawkFan1 HawkFan1 is offline
Vehicle: 2005 Dodge Ram 2500
HawkFan1 is on a distinguished road
Put her in drive and turn the overdrive off. I pull about a 7500lb trailer and have no problems.
Old 03-09-2011, 12:26 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Your truck is designed to pull a lot more than that. If you have a Tow/haul switch, switch to 'Tow' mode and enjoy the trip. If you don't have a 'Tow/Haul' switch, then like BigThirsty suggested, down shift by 1 gear if the trans is 'hunting' (shifting often between gears).
I have pulled much heavier trailers with my previous Ram 2500 trucks, and never had the luxury of the V10. You 'Have' the right truck for the job.
brad
Interested in one of my mods?
Old 03-09-2011, 10:18 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
If your truck is running the stock size tires and and probably 3:55 gears (3:73 is not a chrysler ratio) it should easily handle 5000lbs.
As suggested I would let the truck decide but you can probably run the OD on flat roads, and if the tranny is kicking od to accelerate you may need to run with the OD off. But that big V-10 should haul 5k like a rocket.
I'd hate to try it with a 318, and my 360 would struggle.
FYI: My owners manual says max trailer wt 12k to 13 k depending on cab and bed style and a 5th wheel hitch for trailers over 10k and a class IV hitch for trailers weighing up to 10K
Old 04-07-2011, 10:47 PM
dodgeman9859L dodgeman9859L is offline
Vehicle: 1998 Ram 2500
Trim Level: SLT 4x4 QC
Color: Dark Red
dodgeman9859L is on a distinguished road
ipulled a 1500 lbs trailer with a 6000 lbs truck on top and y truck did great. definitely OD off tho. wish i had trailer brakes to haha. the 8.0l should pull great.
Old 04-07-2011, 10:49 PM
OD in the flat areas, as you start to climb a hill, the truck will tell you when it wants a lower gear.
Does your truck have a Tow/Haul button or just O/D?
Heavy Duty Auto Trans tnmopar Dodge Ram General Discussion 1 11-16-2010 11:16 AM
Floor shift for an auto trans stray dog Custom Dodge Ram Interior Modifications - Custom Audio / Video 5 04-30-2010 02:21 PM
Which auto trans do I have? 99 Ram 1500 Travis Dodge Ram General Discussion 3 02-17-2010 11:27 PM
Auto to Manual trans conversion? xjarhead69 5.2L V8 Specific Topics 4 11-23-2009 07:59 PM
i want to do a trans conversion from auto to manual off road guy 5.9L V8 Specific Topics 1 12-16-2008 08:00 PM
