Old 04-02-2011, 05:46 PM
White98's Avatar
White98 White98 is offline
Vehicle: 1998 Dodge Ram 1500 4x4 QC
Trim Level: Laramie SLT
White98 is on a distinguished road
Put the steering gear box brace on today in between hail storms. Took it out on the freeway for a run and I did notice a difference. But on the real rutted parts it still wanted to go back and forth not as bad but I noticed it. So its better and it was only $140 on ebay. I think I'll start putting some money aside for a new box down the road. I tell ya I love everything about the truck but this steering thing is one PITA!
Old 04-02-2011, 06:53 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:215
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
I got the same problem with the drifting thing... My center link ends are worn, can wiggle the bar by hand with ease so, Im gonna have to replace those soon.
Mike
Old 04-05-2011, 10:56 PM
White98's Avatar
So I swung into the tire shop after work today to get the tires rotated. Started talking to the guy and he said i may have some cross treading going on with the tires. So he suggested swapping front to back. He said the wandering back and forth sounds like the cross treading I've never heard of it. Now I know I need to get some tires cause these were ran with wore out shocks they had some shadowing going on and the other two were cupped from before the rear end was redone. So we swapped em and I tell you what there is a noticeable difference on the freeway not perfect but a whole lot easier to drive. Just thought I'd throw this bit of info out there.
Old 04-05-2011, 10:57 PM
White98's Avatar
Sorry cupped from before the front end work.
Old 05-01-2011, 09:48 AM
zxbud zxbud is offline
Vehicle: 1999 Dodge Raam 4x4
Rep:13
zxbud is on a distinguished road
I'm surprised no one has mentioned too little caster being part of the wander. I drove a new v10 4x4 in 2001 and it steered terrible. Certainly the caster setting adjusters on the lower control arms were way off. Should be set to about 7*.
Old 05-01-2011, 10:12 AM
kzowarrior's Avatar
kzowarrior kzowarrior is offline
Vehicle: 99-3/4-5.9 gas
kzowarrior is on a distinguished road
For me im almost sure its the gear box. I need to save up for a redhead gear. 290 plus tax and shipping and core. I had it aligned a while ago and everything was adjusted there. I think its almost time to get a new truck.
Old 05-09-2011, 06:59 PM
DODGECUMMINSWOODY DODGECUMMINSWOODY is offline
Vehicle: 2001 2500 4x4
DODGECUMMINSWOODY is on a distinguished road
I was just about to post the same thread when i saw your post try pulling a trailer at highway spd you wanna talk about a pita! (and I didn't bring nearly enough changes of under ware ) a six hour trip took about ten I had just bought my ram the PO had changed the stearing box, added a stabilizer, replaced ball joints,tie rod ends etc etc and getting the truck home was just about a suicide mission I thought it had to be due to the fact that it needed new tires so when I got it home that was the first thing I did it didn't make a bit of difference so upon looking at other options I thought about going with a complete poly bushing upgrade and a multi shock stearing stableizer has any one done this and had any improvements with this approach is one better than the other?
New Mods and a DIY for steering maintence sullivan Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 02-23-2011 10:10 PM
Body lift steering extension problem solved JMaxx93 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 0 05-26-2010 12:08 AM
Remerson228 last airbag question awful knawful 2009 Dodge Ram Forum 5 05-17-2010 07:42 PM
changing clockspring awful knawful Body & Interior 2 05-08-2010 05:27 PM
steering issues Redram 5.7L V8 Specific Topics 2 04-29-2010 10:40 AM
