Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 03-10-2011, 08:59 AM
leon leon is offline
Vehicle: 2004 Dodge Ram
Color: Arrival Blue
leon is on a distinguished road
Default fuel foam
Whenever I refuel my 2004 Ram 2500, it foams up and shuts off the pump nozzle prematurely. I can usually get about 2 more gallons in the tank after it 1st shuts off. Do others have this same issue? Is there anything to be done?
regards,
Leon
Old 03-10-2011, 10:01 AM
Rep:1877
Is the gauge reading full when it kicks off the first time?
Old 03-10-2011, 01:31 PM
BigThirsty's Avatar
BigThirsty BigThirsty is offline
Vehicle: 2004 Dodge Ram 2500 4X4
BigThirsty is on a distinguished road
regards,
Leon
That is the nature of diesel. It has a low surface tension which causes the foaming. Nothing can be done other than to try and trickle fill it if the pump will allow. My Duramax held another 2-3 gallons as well after shut off.
2004 Dodge Ram 2500 4X4 5.7
Old 03-10-2011, 06:50 PM
I push the skinny pedal
Rep:3277
Diesel foams... nothing you can do to stop it. I can generally get another 5-10 litres if I let it settle in my SuperDuty.
Kurtis
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
Fuel Fill Nozzle Shuts Off RamTech Dodge Ram Knowledge Base 3 11-22-2013 10:22 PM
SS/T Problems round 2 98sst Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 48 01-11-2010 08:54 PM
Fuel fill problems RamTech Dodge Ram Knowledge Base 3 01-09-2010 11:38 AM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 01:36 PM
