Towing a 5th wheel with the "mighty hemi" - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-10-2011, 11:05 AM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Rep:165
Default Towing a 5th wheel with the "mighty hemi"
Could someone shed some light on this subject. I know the tow/haul rating is pretty impressive for these trucks, I am on the fence whether to consider a 5th wheel or not. My truck is equipped with the heavy tow package with 3:92 gears and 17 inch wheels. I have dug up alot of information on 5th wheel hauling and have some concerns, one and probably the most important being the hitch weight. If I understand it correctly, the 5th wheel hitch weight is usually factored as 15 to 20% of the total trailer weight. Ex: 7000lbs x .20= 1400lbs, now if this is accurate, that is eating up a considerable amount of the payload of the truck without the passenger weights, 2 adults, 2 kids, a dog, camping gear, gas for the truck etc. There is the fact that the frame, brakes and suspension are lighter duty compared to a 3/4 ton chassis, suspension or 1 ton for that matter, obviously. I used 7000 lbs as an example because I felt that would comfortably be within what the truck could realistically haul. Then there is the question whether you can mate a 5th wheel up to a crew cab with the short box, seems to be a grey area. Am I out to lunch here or should I just go with a pull behind and be done with it. I would appreciate your feedback!
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ EFI LIVE 75 HP TOWING TUNE/ OD TUNE/ CARLI ADJUSTABLE TRACKBAR
Old 03-10-2011, 01:29 PM
BigThirsty's Avatar
BigThirsty BigThirsty is offline
Vehicle: 2004 Dodge Ram 2500 4X4
BigThirsty is on a distinguished road
I don't know if I would use the term "impressive". Mabye "par". A Fiver can be done but with a 1/2 ton I would opt for a bumper pull with load levelers and a sway bar. This will help distribute the load over the entire truck verses just over the rear axle which will help tremendously. Now you can concentrate on GCWR verses just payload.
2004 Dodge Ram 2500 4X4 5.7
Old 03-10-2011, 04:21 PM
westxsrt10's Avatar
westxsrt10 westxsrt10 is offline
Vehicle: 2010 Ram 1500 4x4 Hemi
Trim Level: Cool Chrome
Color: Cool Vanilla
Rep:79
westxsrt10 will become famous soon enough
I agree a bumper pull is a far better option for you. I have a ultra-lite 5er and tow it only with my F-250 because of the payload weight. (loaded i'm lust under 200# pin weight with my 3/4 ton)
09 Heartland Sundance 27rl ultra-lite 5er
2010 Ram CC 1500 Hemi 4x4, 3.92 Mag-Hytec diff. cover
2008 Viper coupe, Belanger ceramic headers
2008 Ford F-250 CC,4x4,V-10
Old 03-10-2011, 04:27 PM
With the slider 5vr hitch you can tow a fifth wheel. Short bed owners hate tight turns and the front of the trailer smacking the cab. Usually happens when they are backing into a site. I'd talk a bit more with a local RV technician.
You just have to be careful of load ratings for pin weight (5vr hitch) and GVWR of the truck and how much you will be towing, hauling in the truck and how that all adds up to your truck's rated capacity.
But to avoid that slider hitch operation, getting in and out to adjust it, I'd also look at a tow behind.
Old 03-10-2011, 05:40 PM
rsg1963's Avatar
rsg1963 rsg1963 is offline
Vehicle: 2016 RAM 3500
Engine: 2016-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 900lb/ft (Aisin ASC69RC Automatic)
Rep:48
rsg1963 is on a distinguished road
Not sure about the size of the 5th wheel you are thinking of (length and weight) but on most new 5th wheels you can turn to about 88 degrees without any issues even with a short box. Not all new 5th wheels, just most decent ones. Pin weight should be probably less than 1,500 to stay safe, and remember that a 5th wheel tows far superior to any other hitch so you can load your cargo into the camper instead of the bed of the truck and allow the trailer to haul it. That said, overall gross trailer weight is going to be 10K or less to be safe which puts you around 2K max pin weight, which is too much. So with all this in mind I'd tend to agree that the 1500 is not really suitable for a 5th wheel. Between brakes, frame, axles and springs, it just does not add up as a good decision. I'd have to agree with BigT and go with a standard trailer with a really good load distribution system and decent electric brakes. Maybe even bag it (air bags in the rear for load leveling)
2016 3500 Laramie MC 385/900 with Aisin tranny & 4.10 gears: Bilstein 5100's up front, 20" Fuel rims with 275/65-20 Micheline LTX MS/2 tires, Weathertec Floor mats, 45 gal RDS tank, Hensley TS3 hitch, Billet DEF and Diesel caps, DeeZee tailgate assist, Bull Ring retractable stake pockets, Amp Research steps, hybrid window tint.
Old 03-10-2011, 06:02 PM
Rep:165
I appreciate the input you guys provided, I think it would be quite limiting for choice, I kind of had that gut feeling, so once again thank you, I'm already looking at pull behind travel trailers.
Old 03-11-2011, 11:10 AM
jj ram's Avatar
jj ram jj ram is offline
Vehicle: 2014 Dodge Ram 4x4
Trim Level: Outdoorsman
Color: Maximum Steel Metallic
Rep:16
jj ram is on a distinguished road
A 1500 will do much better with a travel trailer. I have a 6000 lbs travel trailer and my RAM tows it very easily.
Good luck.
"They will not force us, they will stop degrading use, they will not control us, we will be victorious" - Muse
Old 03-11-2011, 12:06 PM
HawkFan1's Avatar
HawkFan1 HawkFan1 is offline
Vehicle: 2005 Dodge Ram 2500
HawkFan1 is on a distinguished road
Good choice I would still consider placing some airbags in it to help.
Old 03-11-2011, 03:24 PM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
if you have ever pulled both the difference is obvious......5th wheel is far superior for handling,ride,control and safety...a large bumper pull trailer will be harder to control and generally more work for the driver......
and if you dont think 10,450lbs towing cap in a half ton is impressive you are silly......a few years back you couldnt tow that in a 3/4 ton......
but at the end of the day the right truck is the answer........
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 03-11-2011, 11:32 PM
deepblue's Avatar
deepblue deepblue is offline
Trim Level: Quad Cab Sport
Rep:65
deepblue will become famous soon enough
I pull a 33', 7800 LB Outback and the RAM does fine. 5.7 and 3.92 gears. I have the Equal-I-zer weight distribution hitch and bed sag is minimal. Not a single problem so far.
Plenty of trailer for my family of 5 and the dog.
--cc
Build Date: MDH:052720 [May 27th (Thursday), 8PM -- 2010]
2010 RAM Sport - Deep Water Blue, 3.92 Gears, Flowmaster 40 Series, Volant CAI w/PowerCore, BedRug, BakFlip F1, Bilstein B6 HDs
-cc
Suspension, Tire, and Wheel Guide 57Hemi08 Dodge Ram Wheels And Tires 169 07-19-2017 01:26 AM
Towing Limits fewtree Towing 25 09-29-2011 09:18 PM
Wheel hop! sprintertech Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 14 02-06-2011 11:40 PM
17" wheels off for new dodge. DODGE4x4 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 11-25-2009 03:28 AM
Wheel Choices - Get Your Vote On! erm Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 33 11-12-2009 04:56 PM
