Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 03-10-2011, 03:23 PM
Danno's Avatar
Danno Danno is offline
Vehicle: 1997 Dodge Ram
Trim Level: SLT Laramie 4x4 Xcab
Danno is on a distinguished road
Default Big drop for little trailer
I have a very small HF trailer that I use for my lawnmower, firewood, etc etc etc. It sits very low, so I haven't been able to use it at all with my truck. I used to use it with the laredo, but that only required a 6" drop. If I want the thing to be semi level then I need to use a > 10" drop, and I'm not finding anything.
My truck isn't raised or anything, is there anybody else out there with this problem? To ad insult to injury I'm about to order new tires for the truck which are slightly larger, probably only adding a teensy bit to the overall height, but certainly not putting me in a better position with only a 10" drop.
any advice on this?
Old 03-10-2011, 03:29 PM
A lot of off road accessory stores, local stores that do lifts, have class III hitch bars dropped > 10 inches. Look for the ones online as well.
Old 03-10-2011, 03:36 PM
Rep:1909
I'd advise installing the new rubber and then measuring the amount of drop you need.
Old 03-10-2011, 03:37 PM
Danno's Avatar
That's what I keep reading, but I've yet to find one. Maybe I'm looking in the wrong places.
Old 03-10-2011, 03:38 PM
Danno's Avatar
Definitely will measure with the new tires on it. I'm going from 265/75-16s to 285/75-16s
Old 03-10-2011, 03:56 PM
Danno's Avatar
Maybe I'll just order the reese 11" drop and see how close that get's me. I need to remeasure after the new tires, though, and an adjustable height hitch would be nicer, since I do tow my dad's larger trailers sometimes (he has a bunch of hitches, too, so it's no biggie)
Old 03-10-2011, 06:31 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
I believe my drop hitch for pulling my camper is 11". I also use a 10 inch regular drop for a boat trailer when I tow it for the inlaws
Old 03-10-2011, 07:19 PM
Danno's Avatar
A guy on another forum gave me this link:
http://www.hitchcorner.com/ball_mounts.htm#drop_down
The difference in price from the 11" and anything greater sure is significant. I hope I can make it work with 11. I think it will be close enough...
Old 03-10-2011, 08:35 PM
The adjustable ones are expensive but worth it if you tow a lot of different trailers.
Old 03-10-2011, 09:30 PM
Rep:1930
My camper one was $160 just for the bar it self. I used the hitch/ball from the old one.
How many coils to cut to get 2"-2.5" drop????? DodgeMyRam Suspension 1 03-02-2011 03:43 AM
Check trailer brake wiring warning lwalston Electrical 1 01-26-2011 06:21 PM
No power to trailer brakes, the blue brake wire has no current rraypo Electrical 1 01-09-2011 09:55 PM
Tekonsha P3 Trailer Brake Controller Doesn't Recognize Trailer GTRDude Towing 13 05-21-2010 06:56 PM
Ball Hitch Drop Ken Towing 5 05-10-2010 08:51 AM
