Old 03-10-2011, 05:51 PM
avenger8692 avenger8692 is offline
Vehicle: 05 Dodge Ram
Color: Metallic Silver
avenger8692 is on a distinguished road
Default fog lights
Ok so my truck didnt come with factory fog lights but already had the wire that i could connect fog lights if i wanted to. So if i bought the fog light harness and the switch my fog lights should work right?
Old 03-10-2011, 06:34 PM
ive put in the fuse, plugged in the switch the fog lights and still nothing. ive put in the fuse, plugged the lights in, plugged the new headlight switch on and the little foglight symbol doesnt light up but my headlights come on
Old 03-10-2011, 06:36 PM
You might need the PCM flashed to add the fogs to the programming.
We had to do that with a 2005 Magnum a while back.
Old 03-10-2011, 06:37 PM
how do you get that done?
Old 03-10-2011, 06:41 PM
Call the dealer.
Old 03-10-2011, 10:25 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
Hey, my 03 came with fog lights but they don't go on when the headlight switch is pulled. The bulbs are good , I haven't tried tracing the voltage yet. Could a re-flash fix this as well?
Old 03-10-2011, 10:43 PM
sk8noregon's Avatar
sk8noregon sk8noregon is offline
Vehicle: 2008 Dodge Ram
Rep:637
sk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to all
Not sure on your 03 but my 08 you push the headlight switch in, not pull it.
"Rocky and Bullwinkle"
Join the "Mineral Gray Metallic Ramz Group" here !
Old 03-11-2011, 01:30 AM
BK24's Avatar
BK24 BK24 is offline
Vehicle: 2008 Ram Quadcab
Rep:21
BK24 is on a distinguished road
I just installed a kit on my 2008 that I purchased on Ebay. It was labeled as an OEM MOPAR fog light kit and came with both fogs, the bezels, a switch, harness, and a fuse (This is not the knob like on factory 08's where you can push in for fogs, it's a seperate switch that you must install). I just had to hook the positive up to the battery, the ground, and a third wire which needed to be spliced into the factory low beam harness. The wire I had to splice into was white with a blue stripe. It may be different for your 05 model. I still have the instructions if you need any further. It only took about an hour to complete the install.
2008 Dodge Ram 1500 ST Quad Cab (4.7L)
Exterior: Mopar step bars, tinted windows, Rhino bedliner, NightRunner Headlights, Sport Front Bumper
Audio: Clarion NX500, Pioneer 6x9 fronts, Pioneer 6.5 rears
Old 03-11-2011, 10:56 AM
I push the skinny pedal
Rep:3277
^^ This is the kit I installed myself, very easy. Now, for the other kits, you must go to the dealership and have them flash the computer to activate the fog lights in the TIPCM.
Kurtis
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 09:19 PM
Installed cab lights now no parking lights on right side MikeEB76 Dodge Ram General Discussion 1 02-18-2011 11:26 PM
Third brake light causing the brake lights to stay on? Due Electrical 7 05-19-2010 03:33 PM
Fog lights wont work Sparkplug469 Electrical 3 04-25-2010 11:31 PM
Part numbers for Lights? DarkRam01 Custom Dodge Ram Interior and Exterior Lighting 4 03-01-2010 11:50 PM
