Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
MOPAR DECALS
Old 03-10-2011, 07:35 PM
rikinwyoming's Avatar
rikinwyoming rikinwyoming is offline
Vehicle: 1996 Dodge Ram 1500 4x4
Color: ticket me red!
rikinwyoming is on a distinguished road
Default Wheel interchage??
I have a 2001 dodge 1500 quad cab 4x4. I want to do a simple two inch level kit to fit 35's (I have 3.92 gearing so they will be okay till I can afford the regear).... question is I have stock steel wheels,,, I love the look but the backspacing is horrendous....
I would like to know what other rims may interchange with my dodge? Maybe 5 lug ford? I believe that I need somewhere in the neighborhood of 3.5 to 4 inch backspacing minimum with a 8 inch wide rim..... I do some offroading but no hardcore stuff!
Thanks in advance,,, didn't find it in the search...
oh and here's a pic of the truck with bald 285's on it ,,, nothing fancy,,, working on it slowly but surely,, ,nice thing it's only got 77k original on the truck, with a 5.9 gas motor!
Old 03-10-2011, 09:02 PM
ScatPak07's Avatar
Rep:970
As long as the bolt pattern is a 5x5.5(139.7) then they will fit. It does not just have to be a 5 bot they do have a pattern. So see if the rims are that then they should go right on...which I think different companies make different bolt patterns. I might be wrong I never have looked into Ford rims haha
Old 03-10-2011, 09:04 PM
part of the reason I asked was because a friend had a set of 5 x 5.5 bolt pattern off a grand cherokee and they did not fit,,, even though the bolt pattern was the same the wheels would not sit flush on my rotors...
Old 03-10-2011, 09:17 PM
ScatPak07's Avatar
Rep:970
I have a 2007 Ram, this info I have is for that. I am not sure what the 2nd gens will be but I think they will be close. I am not sure of the stock backspacing I forget it...I do think it is 5. I know my rims now are a 4.8 backspacing. The other thing would be offset but that should not really affect it. The stock 20s are a +20mm offset, mine now are a -18mm. Not sure what else you would really need to know.
Old 03-10-2011, 09:25 PM
The jeep wheels have a different center hub setup and won't sit flush (they aren't hub centric) so I'm not surprised that's what you found.
It's either going to be an upgraded/newer ram wheel or aftermarket that will fit correctly.
Old 03-10-2011, 09:31 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Off road package rims
Suspension, Tire, and Wheel Guide 57Hemi08 Dodge Ram Wheels And Tires 168 01-27-2017 06:08 PM
1/2 inch wheel spacer on 2010 4x2. Longer Wheel studs? cyberpine Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 23 08-12-2011 05:53 AM
HELP 4 wheel drive Bluebee 5.7L (345 cu in) HEMI V8 Specific Topics 12 12-30-2010 10:35 PM
17" wheels off for new dodge. DODGE4x4 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 11-25-2009 03:28 AM
Wheel Choices - Get Your Vote On! erm Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 33 11-12-2009 04:56 PM
